Thread: Hydraulic Clutch Braided Line - Specs?
Threaded View
  1. #4
    Feb 2019
    Northern Virginia
    I just went through it today. Same setup. https://thefactoryfiveforum.com/show...-line-fittings
    And this is the fitting I used to go from npt to an on the wilwood https://a.co/d/cqV9Idi
    The braided line I linked to in the other thread is perfect length for routing it out the side of the ds footbox. Getting it bled is a bit of a pain though. They explain it here https://youtu.be/wgc7ApCMTGA Keep in mind you literally have to submerge that whole fitting assembly into the fluid. I made a giant mess in the garage
    Mk4 Complete Kit, Blueprint 427w EFI Stage 1, IRS, 15", Gordon Levi Wilwood brakes, FFR Power steering (Build Thread)
    Notes and additions to the official build manual (PM me if you would like access to contribute)
    Inventory tracking spreadsheet
