4
25th Anniversary #9772
yes, it's a science project for sure
I have my #10 wire moved to #6 location, according to johngeorge's setup this is what worked for him.
in the above diagrams, we wired #6 on the ABS module to a HaaT line - which may not be correct given the GT500 wiring diagram at the bottom which talks to the switch
trying to understand the power circuit with relay at the top of the GT500 wiring diagram
if 86/87 are HaaT, and 30 is the switch to turn on 87 which will transfer power from the 85 (PCM) /86 connection?
https://www.delcity.net/documents/au...ay_diagram.jsp
