Thanks Thanks:  113
Likes Likes:  416
Page 17 of 30 FirstFirst ... 7151617181927 ... LastLast
Results 641 to 680 of 1180
Thread: The race is on - Namrups 65 Daytona Coupe build
  1. #641
    Nov 2021
    Portland, Maine
    Quote Originally Posted by Namrups View Post
    Wow, didn't even know this was a thing Scott. Is that kit specifically for the Coupe or is it a roadster kit you modified? I was going to upgrade to a Lokar cable, but I don't like my throttle on/off. hmmmm....thanks for posting all of that and it laid out as you did.
  2. #642
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Quote Originally Posted by rhk118 View Post
    Mike Forte has this kit designed specifically for the Coupe.
    Scott Pregont
    My Albums
  3. Thanks rhk118 thanked for this post
  4. #643
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Throttle install day 2
    First thing on the agenda today was mounting the thru-wall plates for the throttle/actuator arm.
    With that in place I was able to figure out where to attach the rods. I came up with the Sniper rod attached to the crossbar pivot arm about half way to the pivot point and the throttle rod all the way out from the pivot point. This gave me the most movement of the throttle to get to full throttle on the Sniper.
    At this point I started the car to feel the throttle response. I like this setup. Throttle is smooth, controllable and very precise. Having located the positioning of the pivot arms I used a 1/8" drill to drill holes for the roll pins.
    Reinstalled everything so that I can now go-kart. After go-karting I will have to remove the aluminum panels on the footbox so that I can add the heat/sound mats and then final assembly.
    Scott Pregont
    My Albums
  5. #644
    Nov 2021
    Portland, Maine
    Scott, location of that linkage not likely to interfere with the wipers? Looks pretty low.
  6. #645
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Hope not. To early to tell. It's another reason I kept it a low as I could.
    Scott Pregont
    My Albums
  7. Thanks rhk118 thanked for this post
  8. #646
    Shouldn't be a problem. This isn't the best picture, but the only one I have. You can see the wiper boxes and tubs are nearly tight against the top of the body and well up on the firewall.
  9. Thanks rhk118 thanked for this post
  10. #647
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Thanks for the response Paul. I remembered seeing this in your thread and felt comfortable with the throttle setup.
    Scott Pregont
    My Albums
  11. #648
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Go-Kart!!
    We are supposed to get from 4" to 18" of snow starting tonight! Needed to go-kart now or wait till spring. Keeping in mind that I live in the middle of town and it's only 31 degrees I didn't get much over an idle nor did I go very far! Another milestone achieved!
    Scott Pregont
    My Albums
  12. Thanks rhk118 thanked for this post
  13. #649
    That is FANTASTIC Scott! Really excited for you
  14. Likes rhk118 liked this post
  15. #650
    Scott- this made my day- good for you! Inspirational!
    And just a year and a month after your first post!
    Here's to getting to Spring asap!
    Gen III Coupe #17
  16. #651
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Thanks Jeff! More concerning than the snow is the fact I live right in the middle of Mechanicville! No place to run and hide if the cops show up.
    Scott Pregont
    My Albums
  17. #652
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Quote Originally Posted by Dave Tabor View Post
    And just a year and a month before your first post!
    Gen III Coupe #17
    Only 175 days from delivery!! No major hick-ups or delays so far.
    Scott Pregont
    My Albums
  18. Likes JimStone liked this post
  19. #653
    Albany NY
    That is very cool, scott. What does your daughter think?
  20. #654
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Quote Originally Posted by Joel Hauser View Post
    It's hard to say. She has helped me a couple of times but has not shown a real interest. She sat behind the wheel at one point during the build when I only had the drivers seat in and told me that I should put the other seat in so that we could sit in it together. Once it's done and we can cruise in it I think it will be a different story. I told her to imagine me picking her up from school in it. It (and she) will be surrounded by half the boys in the school! Especially if she gets into the drivers seat and drives away! After saying that I thought about it and said maybe that's not such a good idea!!
    Scott Pregont
    My Albums
  21. #655
    Mark Eaton's Avatar
    Medford, Oregon
    Awesome!! Makes me want to build a Type '65 Coupe next!!
  22. #656
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Go for it!!
    Scott Pregont
    My Albums
  23. #657
    Nov 2021
    Portland, Maine
    Scott! Congrats! Sounds great and wow that turning radius!
  24. #658
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    As my daughter would say "Ya I know right!!"
    Scott Pregont
    My Albums
  25. Likes rhk118 liked this post
  26. #659
    May 2021
    Fort Worth, Texas
    Congratulations! Happy to see it all came together for you.
  27. #660
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Quote Originally Posted by Skuzzy View Post
    Thanks Skuzzy!
    Scott Pregont
    My Albums
  28. #661
    Oct 2020
    Albany, NY
    Congrats Scott! Disappointed I couldn't be there. Glad you got it done
  29. #662
    Mar 2021
    Ohio
    That is awesome and a great milestone, nice work! I feel like a kid a Christmas every time I hear one of these cars startup.
  30. #663
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    If we get lucky with the snow I may have a chance to try again on Sunday. If you are available PM me.
    Scott Pregont
    My Albums
  31. #664
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Quote Originally Posted by burchfieldb View Post
    I do also. I found I am looking for reasons to push the start button!
    Scott Pregont
    My Albums
  32. #665
    Mar 2021
    Ohio
    Yes, I have the same problem, even though my engine is currently on a run stand. It is so satisfying to push the start button!
  33. Likes Namrups liked this post
  34. #666
    Chino Valley, Arizona
    Awesomeness - man you trucking along!
  35. #667
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Quote Originally Posted by cgundermann View Post
    Thanks Chris!
    Scott Pregont
    My Albums
  36. #668
    Nov 2022
    Niles, MI
    That 427 is a snarling beast! Love it! Great work Scott!
  37. #669
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Quote Originally Posted by JimStone View Post
    Thanks Jim!
    Scott Pregont
    My Albums
  38. #670
    I love these go-cart videos, especially in the snow!
  39. Likes Namrups liked this post
  40. #671
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Started to install the AC plumbing and ran into an immediate issue. The thru-wall mount has a center-of-hole to center-of-hole dimension of 1 5/8". I measured, re-measured and measured again the upper fitting to line up with the fitting on the AC unit. These lines are very short so getting this in the proper location was very important in my mind. After drilling and installing the thru-wall mount I noticed that even though the top fitting was in alignment the center-of-hole to center-of-hole of the fittings on the AC unit was different.
    I have two issues. First the misalignment of the lower fitting and second the bottom fitting hits the steel brace. As you can see in the pic I can not attach this fitting this way without cross threading it.
    I have discussed this with my expert mentor (yes that would be Paul!) and he had the same issues. I believe we have decided on a solution and I will post pics when completed.
    In the mean time, stay warm and Merry Christmas!
    Scott Pregont
    My Albums
  41. #672
    Houston
    I made it very simple for myself, and eliminated two elbow flow restrictions (minimal)," but every little helps"
    fred
  42. #673
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Quote Originally Posted by freds View Post
    fred
    Great idea. Wish I had seen it sooner.
    Scott Pregont
    My Albums
  43. #674
    Like most everything, has plusses and minuses. Agreed going direct would eliminate the manifold and those crazy short hoses. Which are a pain to get just right. But without the manifold your hose connections would be inside at the evaporator and very difficult to remove and/or service if necessary. Once that evaporator and associated plumbing is permanently installed in the footbox, really wouldn't want to have to get into it. Not a friendly place to work.
  44. #675
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    After thinking about this I will agree with you Paul. Even having the small access panel I think working in that small area once and done is the way to go. Those hoses still need to be insulated to keep frost from melting in the footbox so if there was an issue that insulation would have to be redone also.
    Not being critical of your solution Freds. As they say each to their own. Your solution may never be an issue. But for me I will work this out using the thru-wall manifold.
    Scott Pregont
    My Albums
  45. #676
    Houston
    No skin off my nose. I know! The rest is merely speculation. I have 3,300 Houston miles on my # 50 coupe.
    The suction line hose can be cold The "liquid line" can be warm/hot and having them together is normal A/C good practice. .Also, in the footbox only source of heat is from the heater hoses. "Melt" hoses?.
    Thanks for the reply...I appreciate good manners. And enjoy your build...it's worth the effort!
    fred
  46. Thanks Namrups thanked for this post
  47. #677
    Oct 2021
    Sarasota, FL
    Blitzboy54 stopped by over the weekend and we bleed the brakes. Thanks Jesse for the help and for bringing your pressure bleeding unit.
    Working to get to a point where I can drop the engine in. To do so I need to have some of the engine bay electrical completed. Laid out the positive and negative battery cables. Using 2 ga cable to go from the battery to the master cut off switch. Then from the switched side to the starter with 4 ga. Also from the switched side to a 150 amp breaker to a positive bus bar in the dash with 8 ga cable. Also laid out the negative to the frame with 2 ga.
    Also laid out the rear harness. Shortened the fuel pump and the sender wires for a better fit. This harness will enter the cockpit thru the DS side panel. The rear brake line and the hydraulic clutch line also use this same location.
    Thinking about laying out the dash I decided to follow EdwardB's lead and made up a filler piece between the dash and the front transmission tunnel cover. Now to figure out how to lay out all the switches and buttons.
    SCOTT,
    In your last picture with the steering wheel and column in the Coupe, it shows a gap between the column and gauge sheet panel. When you get a chance, can you measure the gap between the column and the top of the radius.
    Additionally, later I may take you up on your offer for the guides to attach the steering wheel and quick release.
    Bill
  48. #678
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    I will get you the dimension. Let me know on the guides.
    Scott Pregont
    My Albums
  49. #679
    Oct 2021
    Sarasota, FL
    Scott,
    Thanks. I will send you a PM on the guides.
    Bill
  50. #680
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Quote Originally Posted by maclonchas View Post
    SCOTT,
    Bill
    The gap is 19/32". Also note that I had to mill out a space for the RT wiring.
    Scott Pregont
    My Albums
