Hi Chris,
Things are looking great! I also had this same problem and will have to seek a solution like you did; my hoop is actually rubbing on the driveshaft after install. I also used the three spacers from Forte. I will attempt this too, but I have an issue with my e-brake cables coming in contact (especially if I move the hoop up by 1/4"). May have to adjust the brake cables.
