Quote Originally Posted by Namrups View Post
I did spend the money for the 90* adapter. As in the other post the adapter will hit the clutch if put on the DS and there is a steel brace that would have to be modified on the PS to use it. BYW the cable is to big to fit into the adapter and will have to be ground down a little. I think the brace will also have to be altered some if you used the cable on the PS without the adapter. Still looking into it.
Yes, looking at the car there is a brace there on the PS but it might not get in the way once the cable is attached to the bar, worst case is a little will need to be ground away/trimmed to fit it. Gordon's location certainly is the most direct. Looks like in the link Chopper sent above he was able to get that 90 degree adapter fitted no problem. Ordered one and will play around with it. Also considering using that lock nut to prevent myself from overly rear-biasing the brakes with the knob....one more thing to put on the "list" of preferences
