Bulb Sealer | Ken Pike
Does anyone know what bulb sealer Ken Pike uses for the hood, trunk and door jams? I called and left a vm but has not been able to respond yet.
Ken painted my buddies car and it looks amazing, the bulb seal is different than what Factory Five provided and it looks like it allows the trunk and hood to line up better w/ the body.
Matt
i.e.427
Thank you I was looking for this also
I like this option. Anyone have some install pics in the areas mentioned?
Mk4 #9165, Base Kit with lots of options, Delivery on 08/17/2017, Coyote, TKO600, 2015 IRS, 18" Halibrands, 12.99" Wilwoods
Moniz thanked for this post
Interesting, you have it on both your hood and body? Obviously it doesn’t raise the hood up above the body line? I guess if I did you wouldn’t use it. I have this seal on my hood but not the body which would be nice to cover up some of the not so nice paint and the screws for the hood latches.
Mark
Gone but not forgotten. Mk1, Frame #1929 Complete restoration/upgrade.
No, just on the body for the hood opening and on the doors for those, first pic is the door.
John4337
Got it
Thanks!
Mark
Thanks for the pics. I like this seal around the hood. Real clean.
Bulb Seal Temperature Rating
John4337
Which bulb seal temperature rating did you go with?
https://www.mcmaster.com/bulb-seals/...e-mount-seals/
0-140 F
Or
-60-350 F
Padawan
I dont remember getting an option, but it was 10 years ago....
After thinking a bit, I may have used this from Breeze. I'll have to go thru my notes.
https://breezeautomotive.com/shop/d-...5-8-w-x-3-8-h/
I put the hood seal on the hood, so if the hood shifts you can’t see the seal. But that’s just me.
