Results 1 to 12 of 12
Thread: Bulb Sealer | Ken Pike
    Aug 2020
    Does anyone know what bulb sealer Ken Pike uses for the hood, trunk and door jams? I called and left a vm but has not been able to respond yet.
    Ken painted my buddies car and it looks amazing, the bulb seal is different than what Factory Five provided and it looks like it allows the trunk and hood to line up better w/ the body.
    Matt
    Nov 2016
    "The i.e." SoCal
    Is this what you're looking for?
    https://www.mcmaster.com/93085K14/
    Pittsburgh
    Thank you I was looking for this also
    Mar 2017
    moved to Hebron New Hampshire
    I like this option. Anyone have some install pics in the areas mentioned?
    Mk4 #9165, Base Kit with lots of options, Delivery on 08/17/2017, Coyote, TKO600, 2015 IRS, 18" Halibrands, 12.99" Wilwoods
    Copperhill, TN
    Quote Originally Posted by mlewis View Post
    I have it on the hood and doors. I like it. Haven't had any water come in the doors and the hood sits nicely.
  6. Thanks Moniz thanked for this post
    mburger's Avatar
    Punta Gorda FL
    Interesting, you have it on both your hood and body? Obviously it doesn’t raise the hood up above the body line? I guess if I did you wouldn’t use it. I have this seal on my hood but not the body which would be nice to cover up some of the not so nice paint and the screws for the hood latches.
    Mark
    Gone but not forgotten. Mk1, Frame #1929 Complete restoration/upgrade.
    Copperhill, TN
    No, just on the body for the hood opening and on the doors for those, first pic is the door.
    mburger's Avatar
    Punta Gorda FL
    Quote Originally Posted by John4337 View Post
    Got it
    Thanks!
    Mark
  10. #9
    Mar 2017
    Thanks for the pics. I like this seal around the hood. Real clean.
  11. #10
    Aug 2020
    Bulb Seal Temperature Rating
    Which bulb seal temperature rating did you go with?
    https://www.mcmaster.com/bulb-seals/...e-mount-seals/
    0-140 F
    Or
    -60-350 F
  12. #11
    Copperhill, TN
    Quote Originally Posted by Padawan View Post
    0-140 F
    Or
    -60-350 F
    I dont remember getting an option, but it was 10 years ago....
    After thinking a bit, I may have used this from Breeze. I'll have to go thru my notes.
    https://breezeautomotive.com/shop/d-...5-8-w-x-3-8-h/
  13. #12
    Woodstock ,Illinois
    I put the hood seal on the hood, so if the hood shifts you can’t see the seal. But that’s just me.
