Wheel stud replacement question
I may be looking too close and too careful!
I am looking to press in new wheel studs onto the rear hubs of my 33 hotrod irs suspension configuration. I noticed the original studs are notched on the inside to clear center of hub. New studs are not notched and look like thy may hit the rubber gasket protruding from the hub. Any modifications required or when pressed in, do they clear everything?
Thanks in advance.
Attachment 172417Attachment 172418
Best to grind a flat on the edge to prevent interfering with that rubber piece. I've done it using my 8" Delta disk sander. Other tools are possible. Doesn't take a lot. Have done it on my IRS builds, plus a few weeks ago helping another builder.
Build Thread and
Video.
Build Thread.
Build 5: 35 Hot Rod Truck #138.
Build Thread. Sold 11/9/2023.
Build 6: Mk5 Roadster 30th Anniversary #11,258.
Build Thread.
I did the same as Paul, ground a flat into one side just like the originals. I find that a 40 grit flap disk makes short work of things like this
Gen 1 '33 Hot Rod #1104
Thank you both for the response. Folks on the forums have been great.
My bench top grinder worked as well.
Another question on rear stud replacement. (hotrod irs rear end)
Namrups
I started to install the studs and was not happy with the washer approach. Got a Lyle stud installer and seems much better. It took a lot of force and two of the studs threads aren’t right. Tuff to get nuts on stud after installation. Stopped after I ran into this problem. Given they are 1/2 20 studs…
Question 1 any recommendations to installing and making sure I don’t damage stud threads? Freeze studs and use oil? Don’t reuse nuts after 1 installation? Etc….
Question 2 anyone know a specific PN of a stud to replace ones that I am not comfortable with?
Any help appreciated.
Thanks again. John
