Well, I decided to take a closer look at the Ford manual.
Pretty clear directions at the bottom:
"WARNING: Before installation, prime the engine by removing the oil pressure switch from the filter adapter. Install
appropriate fitting and using a pre-lube tank to prime oiling system. Verify that the oil reaches the valve train, valve
cover removal may be necessary. Oil at the valve train confirms the engine is primed.
Check oil level and fill as necessary."
Guess it's off to the store for another quart of 5W-50.
32J
