Thanks Bear. I was looking at the NT01's; planned on going with those for the first set and see how the 100 treadwear holds up.No issues Front NITTO NT-01 @ 275/40ZR17-98W Rear NITTO NT-01 @ 315/35ZR17-102W. Prior front till it wore out at 9,000 miles was a 255 NITTO 555R also 315 555R in the rear.
Car runs a 4.25" ground clearance
FWIW the Nitto NT-01 275 18" 35 aspect ratio is the same dimensions as the NITTO 17" 40 aspect ratio version.
17" 25.55 tall X 10.91 wide 18" 25.55 tall X 10.91 wide
