Thanks Thanks:  11
Likes Likes:  28
Page 1 of 3 123 LastLast
Results 1 to 40 of 83
Thread: Battery location doubts
    Feb 2020
    Tucson, AZ
    I’ve installed the battery in the trunk directly behind the seats as instructed in the manual, but upon standing back and looking at it, it appears that it will be far inside of the actual truck lid opening. Will there be issues removing/replacing the batteries with the hold down studs being near the top of the trunk compartment and close to the body? Any firsthand experience here would be appreciated.
    Jan 2021
    Memphis, TN
    FFR Metal battery box, can't beat it:
    https://www.ffmetal.com/index.html#bb
    FFR Roadster Delivered 9/16/21
    Forte 427 Fuel Injected with TKX Transmission
    Forte's Axle
  3. Thanks Jaguar Engineer thanked for this post
    Likes Jaguar Engineer, svassh liked this post
    Feb 2020
    Tucson, AZ
    Quote Originally Posted by CaptB View Post
    Great idea, thanks
  5. Likes CaptB liked this post
  6. #4
    Dec 2013
    Sandia Park, NM
    Until you need to replace the battery!!
    FFR #8305; IRS, 347; T5 Trans; EFI, 3.27 Rear; 17x9" Front; 17x10.5" Rear
    Paint - Ford Magnetic Metallic Gray (J7) with Black Stripes; Painted by "da Bat"
    Complete Kit Delivered 05/15/2014; Titled and Registered 4/14/2017 as a 1965!!
  7. #5
    Nov 2018
    Centennial, CO
    You have the option of installing it in the engine bay too. Breeze makes an excellent battery box for this purpose and it makes it very easy to get to the battery.
    Bradley
  8. Thanks Jaguar Engineer thanked for this post
  9. #6
    Brooklyn Park, Minnesota
    Several of us have opted to relocate the battery up front. You may want to investigate this option. Several advantages, shorter cable leads and improved access.
    MKII donor build using 1990 LX. 5.0, EFI, 5sp. 3 Link, 3.55 gears, 5 lug disc. brakes, 15" Halibrand style wheels and other upgrades added over the years. On the road since 2003.
  10. Likes AROCK liked this post
  11. #7
    Jan 2021
    Memphis, TN
    Quote Originally Posted by swwebb View Post
    I've found if you get right over the battery box and lift straight up it comes right out.
    Forte's Axle
  12. Likes AgileYeti liked this post
  13. #8
    I am one of the several Flip Smiley mentioned. Made my own battery box, sorry Mark ( I did buy a lot of your other stuff ), and used the space that the ffmetals box goes in as a tool box. Here are some old pictures from the build. I have replaced the battery since then and it was pretty easy to do.
    Norm
  14. Thanks Jaguar Engineer thanked for this post
    Likes Jaguar Engineer liked this post
  15. #9
    Feb 2020
    Tucson, AZ
    Norm
    The tool compartment is a nice touch.
  16. #10
    Flip and I made a video of locating our batteries in the engine bay. We talked about the advantages as well. Easy to get to, short battery cables, more trunk space, etc.
    https://youtu.be/mUXRIsNmBc4
    If you have a 302 or 351W, there is plenty of room in front of the engine.
    then you have more space for chairs, tools, blankets, beverages, etc in your trunk.
    Mike Davis
    Pepper Gray Metallic with black metallic stripes ("Eleanor" colors) Mark 2 FFR
    351 Windsor, tremec 3550 5 spd, 3 link rear end
    http://cobra.prairieroad.com/
    1982 Honda Goldwing Aspencade restored in 2008
  17. Thanks Jaguar Engineer thanked for this post
  18. #11
    Jun 2020
    St. Paul
    I'm using the FF Metal box. No issue getting the battery out. I also had custom battery cables made in 1/0 to prevent the current restriction issues with 4 gage that comes with the kit. Everything works great. custom battery cables .com $200.
    FFR Roadster 10032 - Ordered Oct 2020, Received Mar 2021 - 95% done before paint. BPE 347, Sniper, TKO. Build School Oct 2020. St. Paul, MN
  19. #12
    +1 to CaptB's suggestion. It tucks it away nicely. A small challenge to remove, but I am fashioning a sling to place underneath to help facilitate removal. It will have a handhold on either end, slip underneath the battery, and when it's time, I can just grab the handles and lift.
    As far as the long runs, as others have mentioned, just use the right size cable, and that is a nonissue. I also like the idea that the weight is centerline above the IRS.
    Either location will work great, but we each have our preference...
  20. Likes CaptB liked this post
  21. #13
    Jan 2020
    State of Jefferson
    Quote Originally Posted by Jaguar Engineer View Post
    Another Breeze front mounted battery fan here, anything to free up more space in the trunk it is prime real estate in there. Also very easy access to the battery in front of the engine.
    https://www.breezeautomotive.com/sho...-1-4-roadster/
  22. Likes JB in NOVA liked this post
  23. #14
    St. Helena Island, SC
    Breeze front battery box! Simplifies everything and your back will thank you later.
  24. #15
    Grand Rapids, MI
    I'm planning on a Braille B3121 under the upper floor to the right of center and over the 2015 IRS support framework. Might be a bit tight but so far my models fit.
    Big battery cable solves the wiring issues.
    Front location is dedicated to Accusump, Laminova oil cooler and the power steering cooler.
    Jim
  25. #16
    Colorado
    We love our front mounted Breeze box. I would do it again in a heartbeat.
    Mk4 Roadster with BluePrint 347 with Holley EFI and solid axle rear end.
    Build thread
    Body work and paint thread
  26. #17
    Edmond, OK
    Another happy Breeze battery box customer here.
    In hindsight - I probably should have investigated the trunk battery box to gain additional space in the trunk area - using that for tools is an excellent idea.. I did use the Cobra Earl drop trunk and very glad I did so.
  27. #18
    Feb 2020
    Tucson, AZ
    Quote Originally Posted by OSU Cowboy View Post
    Could you elaborate on this Cobra Earl drop trunk? Are there instructions or a kit somewhere?
  28. #19
    Quote Originally Posted by hineas View Post
    If I had adequate room under the hood to mount my battery, it would have certainly been mounted there.
  29. #20
    Jul 2019
    Georgetown, TX
    I would like a glove box where the battery is usually installed, so I’m thinking of moving it over to the passenger side tucked under the roll bar. I’m not really concerned about trunk space, so the extra work of a drop or front mount doesn’t seem worth it. Reasonable?
  30. #21
    Quote Originally Posted by PaulRSchmidt View Post
    The centre of the trunk floor is reinforced to support the battery in the position directed by the instructions. Outside of this area the battery will be sitting on the aluminum sheeting without support. Not sure if that is a great idea.
    Norm
  31. #22
    May 2020
    Quote Originally Posted by Jim1855 View Post
    Jim
    Highly recommend antigravity lithium battery rather than Braille. A little more expensive but only 25% of the weight and they seem to be a lot more reliable than the Braille AGMs. Mine only weighs 5lbs and it cranks a high compression 376 way faster than my Braille ever did, and it doesnt lose charge sitting for a month off a tender like the Braille did
  32. #23
    May 2020
    If you get a high end lightweight battery you can put it wherever you want. If you have a 50lb battery it needs to have the added support like the "factory" location
  33. Thanks PaulRSchmidt thanked for this post
  34. #24
    Jul 2019
    Georgetown, TX
    Quote Originally Posted by Hoooper View Post
    Would an Optima Red Top qualify as lightweight?
    There’s a 1X1 running diagonally mostly under the intended battery location, too.
  35. #25
    Sep 2018
    SF Bay Area, CA
    A red top is lighter, but not light. If you do move it somewhere else, you need to add a backing plate or secure the battery hold down through a frame member. I would definitely not trust any battery tie down that's simply going into .040 aluminum to restrain a battery in an accident.
  36. #26
    Jul 2019
    Georgetown, TX
    Ah, fair point. I had been thinking of fatigue, not an accident.
    If I decide I don’t need a heater (TX), the point becomes moot, as I’ll install a glove box in the traditional location.
  37. #27
    You can have the heater and a 3 inch deep glove box in the standard location with a little fabrication skills. I made a box that moved the heater 2 1/2 inches forward to allow for this. Here's another old picture.
    HTH
    Norm
  38. Thanks PaulRSchmidt thanked for this post
    Likes JohnnyB liked this post
  39. #28
    Mine is mounted on the right side of the lower trunk floor. It doesn't take up to much room, and is easy access for charging or replacement.
    I think that was FFR's suggested location for the MK3.1 builds.
  40. Thanks PaulRSchmidt thanked for this post
  41. #29
    Dec 2021
    Antigravity batteries are really cool, especially with the remote jumpstart option. But I wouldn't say they are "a little more expensive". They're quite a bit more money.
    They last longer, require less maintenance and in my opinion are absolutely worth the cost, but still a good amount of $$$ up front.
    Complete novice who doesn't know what he's doing.
    MKIV with BPE 347 & TKX. IRS. A crap ton of mods.
    Build thread
  42. #30
    May 2020
    Quote Originally Posted by zee View Post
    Not that big of a difference on these cars once youre already comparing the Braille he referenced, the antigravity I have was $350, the Braille is $250. For a new car that has big power demands yeah there is a major difference those can be around $1k.
  43. #31
    Dec 2021
    $350? Which one?
    Build thread
  44. #32
    May 2020
    $350? Which one?
    atx-20-hd
  45. Thanks zee thanked for this post
  46. #33
    Mar 2013
    Fort Collins, Colorado
    Do a search for "Dropped Trunk Mod", and a half dozen or so will turn up.....Not too hard to do from scratch, but the kits do make it easier if you do not have access to a bending brake or an aluminum source.
    I dont think that Cobra Earl is making them anymore, but Russ Thompson http://www.norcal-cobras.com/store/r...age/index.html makes a few sets when he gets enough requests.
    I did mine about 4 years ago from scratch, and on a completed car. It would have been 10x easier without the body in the way, but it is do-able.
    At the same time I moved the battery from the right side of the trunk floor to a clone of a FFMetal box.
    Together, it has added an enormous amount of useable room in the trunk.
    Highly recommended.
    MK2 #3319.... On the road since 2002 with a lot of upgrades
  47. #34
    greenwood sc
    I have the FFmetal box in my 2011 MKIV. Very nice. To be honest, I have the same battery in there since 2012. I ran a charger lead out the trunk and it stays on a tender. I am running a regular big box store battery, nothing fancy.
    MKIV #7619 complete kit IRS, 351 TKO 500, Delivered 11/13/2011
    First start 12/31/2011
    Gocart 01/12/2012
    completed tags/title 05/11/2012
    http://thefactoryfiveforum.com/showt...-Graduate-7619
  48. #35
    Weatherford, Texas
    I mounted the FFR battery box under the upper trunk floor with a couple of simple metal straps screwed to the frame. Will fashion a hinged door in the trunk aluminum for access. Seems to be plenty of room for battery removal when the time comes.20220330_125440.jpg
    FFR 5818 MK3 build restarted.
    331 EFI stroker, T5-Z, 3.08 gears. BBK shorty headers -> FFR cats & side pipes.
    Recent: 5 lug & Rear disc swap, Halibrands. Next: ePowersteering, 4 to 3 link, E-Stopp, ProFlo4.
  49. #36
    Dec 2021
    atx-20-hd
    I don't know how I missed that. That battery is so small, it can go anywhere!
    I remember you posting once that you put the battery on top of the pax footbox. Do you have a picture? Thanks.
    Build thread
  50. #37
    Jax Beach, FL
    I replaced mine last year. 8 years after it went in. Easy operation. There is a hole in the bottom so you use a jack and a piece of wood and it pops right out. Then you easily lower the new one down.
    It is something that needs to be done every 7 - 10 years. Is access really a concern?
    You also don't want to add weight to the front of the car. That is why the engine is so far back. Heat is also not good for a battery.
  51. #38
    Edmond, OK
    Cobra Earl is no longer with us. He made a couple of enhancements available to people for years. His drop trunk utilized the space between the middle-to-driver side area of the gas tank, recessing the trunk floor below the 1" rear frame rails that support the as-designed trunk floor along with providing a crunch zone for rear-end collisions presumably. I know there is some other vendor on the forum that supplies similar.
  52. Likes smccoy liked this post
  53. #39
    You guys can spend all you want, but my Odyssey PC 680 is 6 yrs old has never needed maintenance or charging. It's only $173. Why would you want to spend up to a grand?
  54. Likes Ted G liked this post
  55. #40
    David aka Ducky2009
    Lilburn, GA
    The front battery box is a great option, but remember it's a smaller battery. Suggest you add a battery tender to keep the charge up if it's going to sit for an extended time.
  56. Thanks CaptB thanked for this post
