Call Mark at Breeze.
Seriously though, there are a few ways you can route the PS lines. If you're not planning to install a PS cooler, Mark actually recommended to me to use 135 degree fittings for both the supply and return coming out of the rack. This will route the PS lines behind the rack rather than in front of it, which is a more direct route back to the pump. That ultimately didn't work for me since I installed a PS cooler, but it may work for you and allow you to miss your brake lines. I have those 135 degree fittings if you want them.
