So I wired one headlight only just like Edwardb and 33fromSD said. when in accessory mode the amber light turns on. When pulling out headlight switch on click the dash lights come on, then pull out another click and low beams come on, when pulling out for the last click I get the same low beam. the high beam toggle switch works. Here are my questions:
- I ONLY wired and tested drivers side headlight. I get no blinker. Do I need to install other side headlight to get it to work correctly?
- Rear tail lights are wired, bright red lights are on tail lights. Do I need to adjust the brake light sensor down by the brake pedal? I also get no blinkers. Thank you
- how do I get the white LED light to work as a DRL?
