Thanks Thanks:  54
Likes Likes:  130
Results 1 to 40 of 487
Thread: Danny Boy's Mk4 Build - Putting the project on hold for a while...
Threaded View
  1. #11
    Jan 2020
    State of Jefferson
    FOM, what are you trying to accomplish by coating the inside of your trans tunnel? Heat reduction? Just a suggestion, go out buy a roll of thermo tech and peel and stick it on. No mess or toxic fumes to breathe and will do the task of heat and noise reduction. You can also it inside the top cover piece as well, I should also add the trans tunnel does not get that hot to begin with, nothing in comparison to the firewall area. One other tip, when you install your engine/trans slide the drive shaft in when transmission is coming through the tunnel area. You will have much more space to work with, we did this on a friends build and it was much easier doing it this way then trying to squeeze it in once the transmission is fully pushed in and mounts are installed.
    https://www.amazon.com/Thermo-Tec-14...e%2C255&sr=1-5
  2. Likes facultyofmusic liked this post
