Quote Originally Posted by mcamera View Post
I can't get the 3 parking lights to light up. What did you guys do? I have 11v of power from the power wire and I've confirmed the ground wire is grounded. Double checked that there is 11v between the power/ground wire and still not even a flicker. I've tried 2 parking lights to make sure 1 wasn't dead. There are 3 wires coming out of the LED. Black, white, and yellow. I've tried every combination on a 9V battery and still no luck. The headlight low beam, headlight high beam, and blinker are all working fine. The attached schematic shows the wires I'm using which are part of the Subaru headlight plug. Thank you for any help!
Up the voltage. My running LEDs wouldn’t come on until they hit 12, at 14 they got nice and bright. I used black and either yellow or white for positive. I don’t think it matter which one I used, they lit the same for me.
