All I can ad is after building 3-33's and a 35 if you run fully enclosed sides your vehicle will overheat in weather above 80 degrees. Especially using the A/C. Most hot rod guys here in FL take their sides off in warm weather to avoid overheat problems. Michigan is much cooler than FL so maybe not the same. Not sure how many days above 80 you get up there. Best of luck.
