84
481
toadster
yeah, if FFR could actually ship the A/C unit I could start the fab work! they're SOOOOO backordered right now!
Agreed, I can cook up a storm for the next get-together! Nobody will go home hungry!
I'm currently fitting up, prepping to drill the rollbars - but the darn things are stuck! the tolerances are really tight! Trying to take my time and not scratch the chrome, I've used gloves and no luck... one of those walk away moments for sure!
edit: got them 'un-stuck'
noticed there's a little bump on the front supports, I assume those are 'stops' and not something I need to drive the bars 'past' to lock them in?
the manual shows what I think is an older style where the rollbars go inside the mounts
Are you using a Cobalt bit? that is hard steel and it will destroy any other bit than a Cobalt. I bought two Cobalt bits, one for a pilot hole and the other larger for the bolt. I also used the 520 Speed works boltless kit for upper bolt, nice setup and eliminates the Frankenstein bolt and risk of chipping the roll bars where you can see it.
I honestly do not recall those stops/bumps on mine, I just pushed down the bar as far as possible. They definitely could have been there just did not see them. Probably did not notice them because I stopped reading the manual half way through my build
