All,
What have you used for 15 inch rims outside of the Factory Five offering? I ordered rims last July and my order was just pushed back another 6 weeks....
Very interesting. They also make pin-drive options in various backspacing in 17" & 18". One wonders if they are capable for 15" also. I dropped them a note.
A better question is what 15" tires are available. Because if you want something with grip in a 15" offering, you're pretty much out of luck. If all you plan to do with the car is go to car shows and Car & Coffee you'll be fine. On the other hand, if you think you'll be wanting to do any open track or auto-cross, plan now for a second set of wheels and tires in a 17 or 18 inch size.
All,
15 x 8 and 15 x 10, cast finish, with knock-offs, lug covers (will clear PBR calipers)
8" wheel 5.25" BS, 10" wheel 6.25" BS
As I understand, they use to produce the wheels for Factory Five.
Thoughts?
Thanks in advance...
Go to ET Wheels (also Team 3 wheels). They offer nice Halibrand replica wheel packages (AC lll) in various sizes including 15 inch diameter specifically for Factory Five roadsters.
358 SBC, Winters QC, Sweet mfg, Coleman, AP Racing, ARS, TKO 600, Fuel Safe
Would you think these would grip?:
Goodyear Vintage Sportscar Eagle Cobra Tire Bias Ply [26.5 x 10.0-15]
Part Number: 478-2547
Not true. There are really good 15" tires out there, they just are expensive. Just pick up a set of AVON'S, they are as good as any 17 or 18" tire.
The Cooper Cobra'a are a good street tire, marginal as a performance tire.
What are the dimensions of the center hub spinner adapter for the FFR Halibrand bolt-in replica wheels? The Rocket wheel's adapter hub bore is 3.08" on the Sunburst and then tapers down to 2.79" where the center cap sits. Their spinner is branded, while the Halibrand is not, and unbranded is good.
Might the Halibrand adapter fit in the Rocket Sunburst wheel?
My understanding is factory five’s wilwood set up does not work with their 15” wheels. Check with Gordon Levy (forum sponsor?), he has wilwood set for this application.
Respectfully,
Jeremie
Respectfully,
Jeremie
Thanks Chief!
Forte's Axle
