Likes Likes:  2
Results 1 to 16 of 16
Thread: Hydraulic Clutch | Test
    Aug 2020
    We got the car into gear, out of gear…
    …but we when we took off the clutch while in gear the car without giving it any gas the car did not die.
    We were expecting the car to die when I released the clutch.
    The car is on stands, no wheels on car.
    Thoughts??
    Dublin, OH
    Do the axles turn?
    Jul 2020
    Marco Island, Fl
    Not an expert but if it is in the air with no wheels then there is nothing to stop the drivetrain from revolving, as long as it is revolving it will run. The idle speed of the motor is enough to move everything enough to not stall.
    Chris: FFR MK4 Roadster complete kit, delivered 8/17/2020, 347BPE CI, TKO600, Moser 8.8 3link 3.55, Halibrand 17x9 17x10.5, man-power brakes and steering, breeze radiator components, FFR adjustable seat mount (D), Breeze seat mount (P), leather wheel, drop trunk, hidden trunk battery.
    Aug 2020
    Do the axles turn?
    Yes, the axle and wheel turn/spin
    Dublin, OH
    As Capt said, with no wheels on and with the car up on jacks, there may not be enough friction/ inertia to stall out.
    Aug 2020
    I’ve got an email to Mike at RAM Tech… I think y’all are right but I’ll follow up with what he responds back with.
    Omg. Why would you think the engine should die? It's on jack stands, there is nothing to stall the engine.
    Quote Originally Posted by Padawan View Post
    Thoughts??
    You're seeing torque and gear reduction at work...it's doing exactly what it should do.
    Jul 2019
    It's doing that because it's supposed to do that. But running the drive train on jack stands may not be a safety conscious decision.
    Aug 2020
    All,
    First, I loved the OMG comment I'm not a mechanic so when I have a question I take it to the forum. And the forum has been wonderful...so yes, I'm fair game to being make fun of -- I'll take it with pride
    RAM Tech had never tired to stall a car on Jack Stands with no wheels...
    I tested again this morning...I put it into gear...the wheels spun, took it out of gear...wheels stopped spinning.
    The Hydraulic Clutch as the forum confirmed looks to be preforming as its intended.
    Thanks for all the responses.
    Side Note -- if you use the RAM Hydraulic Throwout Bearing for a T5 and 302 -- I would look at this instructional install video (use RAM tolerances as recommended)-- way easier to do the math: https://www.youtube.com/watch?v=XohLNeiOUEw
  11. Likes RoadRacer liked this post
  12. #11
    All,
    Don't stop asking.. it's the fastest way to learn.
  13. #12
    Fairfax Station VA
    What RoadRacer said. I've asked some questions that in retrospect were really dumb...but learned from each one & the answers got me back on track post-haste.
    MK IV Roadster #8631
  14. #13
    Jul 2020
    Birmingham, AL
    I had asked a question about what an outer Diameter of pipe was that required beyond simple math to get the answer I should have known a couple of months ago. I was so embarrassed at the time. Don't feel bad or sweat it. These folks are good people and most really want to help
  15. #14
    The most ignorant question is the one that is never asked.
    Don't fret because everyone on the forum is here to help.
    Wrench On Brother, Wrench On!
  16. Likes nucjd19 liked this post
  17. #15
    Aug 2020
    Side Note - RAM Clutch, Flywheel, RAM Hydraulic Throwout Bearing 78130 - 5 dark and 1 gold shim for a total of .160 tolerance
    Measure twice — hope this helps
    First time — I got 2 shims using the RAM video
  18. #16
    May 2019
    Hayward, CA
    The definition of a stupid question is when you already know the answer but ask it anyway.
    Keep building your dream.
