Thanks Thanks:  68
Likes Likes:  513
Page 9 of 15 FirstFirst ... 7891011 ... LastLast
Results 321 to 360 of 589
Thread: Jim's Build Thread
  1. #321
    Jun 2020
    SoDak
    Looks good Jim. I spy 5 snow shovels, wow. Guess you must get a lot of snow!
    LOL...yeah...we do usually (this year has been fairly mild, not complaining), but those are just the ones we have if we get a big storm and everyone (wife & kids) needs to shovel...the ones I primarily use (scrapers & snow blower) are on the other end of the garage in front of the 33.
    Jim
  2. #322
    Jun 2020
    SoDak
    Quote Originally Posted by HVACMAN View Post
    Which Fuji Q4 did you wind up purchasing, if you don't mind me asking?
    Hey HVACMAN
    This is the one I bought (Fuji Spray Q4 Platinum - T75G) as well as I bought an additional T75G gun
    https://www.amazon.com/Fuji-2894-T75...5026942&sr=8-2
    Jim
  3. Thanks HVACMAN thanked for this post
  4. #323
    Jun 2020
    SoDak
    Took my 55 F100 off the rotisserie this morning so I can start stripping it and prepping for primer. The Chassis with new box is up on the lift behind it.
    Jim
  5. Likes RoadRacer liked this post
  6. #324
    Jun 2020
    SoDak
    Belly pan and both fenders finish sanded....too much sanding this week with all the panel prep I did and then adding finish sanding of the primer on top of that, my hands started cramping up so I didn't have enough in me to start on the engine side covers today. I'll tackle those tomorrow and then move on to the hood.
    Jim
  7. Likes RoadRacer, FF33rod, narly1, peterh226, JimLev liked this post
  8. #325
    Jun 2020
    SoDak
    Engine Side covers finish sanding is now done as well. Also prepped the outside of the hood, removed the hood and went to start on prepping the inside of the hood and my hands started cramping up again so I'm quitting for the day.
    Jim
  9. Likes RoadRacer, FF33rod, narly1 liked this post
  10. #326
    Jun 2020
    SoDak
    Hood and cowl now prepped for primer as well....inside of the hood was a PITA to prep...
    Jim
  11. Likes RoadRacer, narly1 liked this post
  12. #327
    Jun 2020
    SoDak
    Hey HVACMAN
    Jim
    Q4 Platinum Fuji Spray system arrived this morning (sorry about the mess around it). Hoping to try it out this weekend when I prime the hood & cowl....a lot depends upon the weather though. Jim
  13. Likes FF33rod, HVACMAN liked this post
  14. #328
    Jun 2020
    SoDak
    Tear down continues for more body prep this weekend. Removed the dash components, wiper, and windshield as well as the tail lights / backup lights.
    Unfortunately I may not primer the hood / cowl this weekend due to a huge weather system coming in targeting us with over an inch of rain to start out and then transitioning to 3-6" of snow(maybe more). It may be way too damp to prime.
    No worries, plenty of body prep to keep me busy.
    Jim
  15. #329
    Kingwood Texas
    That's the same system that I have. It took me a while to figure out that conventional nozzle sizing doesn't really translate to this low pressure system so don't hesitate to experiment with that. I find myself using a smaller nozzle size than what I'd expected.
    33 HotRod #1142
    Started 5-9-19
    Kingwood, Texas
  16. #330
    Kingwood Texas
    Thanks James....Yeah, I think it will really pop on the 33.
    Jim
    I agree, and it's different that what we normally see on the HR's
    33 HotRod #1142
    Started 5-9-19
    Kingwood, Texas
  17. #331
    Jun 2020
    SoDak
    Started out this weekend masking off the dash area, under the dash, the trans tunnel area and the floor since there is going to be a ton of dust going on now that I've started on the main body.
    One advantage of doing thing myself verses having body shop do it is I can be a little more picky about keeping the dust down in certain areas. When I get to spraying, I'm going to mask off the bottom of the 33 too to avoid excessive overspray on the various components.
    Once that was done I sanded / prepped the dash area for primer
    20210313_064422.jpg 20210314_062023.jpg 20210314_062031.jpg 20210314_062042.jpg
    Next, I moved on to door gapping, sanding and prep for primer. Driver's door is completely done on the outside, I'll do the inside and top of the doors when I remove them to do the jams. Still working on the passenger door, I had some deep scratches on the passenger door that were there when it was delivered that needed to be dealt with. Almost like it was not tied down completely during transport and was rubbing on another kit next to it.
    Both doors ended up lining up really nice with all the body lines and between panels. I found that from the edge of the doors inwards about 1-2", they both had some funky waviness and sunken spots in the gel goat that had to be filled in, but no biggie, just a little more effort.
    20210315_183518.jpg 20210315_183531.jpg 20210315_183548.jpg 20210315_183558.jpg 20210315_183610.jpg
  18. Likes narly1, JimLev, RoadRacer liked this post
  19. #332
    Jun 2018
    North Vancouver, BC, Canada
    Wow that is amazing alignment on the doors. Having the top of the doors even close to the rest of the body when the outside belt line is aligned is a miracle, at least for gen 1 guys.
    Congrats, looking great!
    Gen 1 '33 Hot Rod #1104
  20. #333
    Jun 2020
    SoDak
    Thanks Steve
  21. #334
    Jun 2020
    SoDak
    Has any drilled weep holes in the bottom of their doors for water escape?
    Thinking about it this morning, I don't recall seeing any (I'll find out for sure this weekend when I remove the doors) so figured I'd ask the group.
    Jim
  22. Likes narly1 liked this post
  23. #335
    Jun 2018
    There is no flat bottom on the door, it's a wedge. I'm going to drill one or two holes at the bottom of the wedge (right where it starts to angle up on the inside) but they will be sealed by the weatherstripping on the body when the door is closed. I'm not going to park the car outside in the rain for days so figure it will be okay. Just need to open the door after washing, etc....
  24. Thanks 33fromSD thanked for this post
    Likes 33fromSD liked this post
  25. #336
    Jun 2020
    SoDak
    Thanks Steve... yeah mine will be garaged most of the time too (except when driving) and I don't have windows holes cut in the top of my door which provides more coverage from water but to be safe I'm going to do the same and drill some holed in the door to allow any water that may get into the door escape.
    Jim
  26. #337
    Jun 2020
    SoDak
    Outside of passenger door completed / prepped for primer... panel alignment turned out good....just like the driver's door, I'll do the inside prep once I remove the doors.
    20210318_164041.jpg 20210318_164059.jpg 20210318_164121.jpg 20210318_164132.jpg 20210318_164217.jpg 20210318_164308.jpg
    Jim
  27. Likes JOP33 liked this post
  28. #338
    Jun 2020
    SoDak
    Running boards, rear fenders, trunk lid and surrounding body all prepped........... I'm pooped!!
    I'll pull the trunk lid, & doors tomorrow so i can do the inside of those panels and then all I have left are the door & trunk jams and I'm ready to shoot primer hopefully next weekend.
    trunk handle / latch are removed so the trunk lid is up just a bit, sides pull down even with it latched.
    Jim
    20210320_071630.jpg 20210320_071646.jpg 20210320_071705.jpg 20210320_071718.jpg
    20210320_133803.jpg 20210320_133818.jpg 20210320_133846.jpg 20210320_133911.jpg
  29. Likes RoadRacer liked this post
  30. #339
    Village Mills, Texas
    Hey Jim, what tips do you use for the epoxy and the paint/primer?
  31. #340
    Jun 2020
    SoDak
    This is what I'll use
    • 1.8 for epoxy
    • 1.3 or 1.5 for primer; for 1.3 need slightly more reducer
    • 1.3 for paint
    • .8 for clear
    Jim
  32. Thanks HVACMAN thanked for this post
  33. #341
    Jun 2020
    SoDak
    Trunk lid & doors removed.....also masked off the bottom of the car in preparations for all the upcoming spraying, and since it was now masked off I sprayed rubberize coating on the bottoms of the running boards and rear fenders to hopefully eliminate spider cracking in the paint due to stones on the under surfaces. And it makes it look more finished.
    Jim
  34. Likes FF33rod, narly1, peterh226, HVACMAN liked this post
  35. #342
    Kingwood Texas
    • 1.8 for epoxy
    • 1.3 for paint
    • .8 for clear
    Jim
    I recently changed my spray gun cup to the 3M PPS 2.0 system and couldn’t be happier. Clean up is way easier, far less solvent needed too. I had several instances of a dripping cup with both the plastic and stainless Fuji cups with the gun held horizontally. The 3M system is a huge improvement on that. I can even shoot consistently with the gun upside down now without leaks.
    33 HotRod #1142
    Started 5-9-19
    Kingwood, Texas
  36. #343
    Jun 2020
    SoDak
    Quote Originally Posted by Michael101 View Post
    Hi Michale
    I was looking at that system on you tube today......The only issue is the video really didn't specify any part numbers (like the adapter for the Fuji gun, the 3M PPS 2.0 kit, disposable cups, etc) so I'll need to do some research.
    Jim
  37. #344
    Jun 2020
    SoDak
    Hi Michale
    Jim
    Found what I need, and ordered the 3M PPS 2.0 system.....all parts should here Friday.
    Jim
  38. #345
    Jim
    Which part number did you decide on? This will be my first attempt at bodywork and paint. I am determined to complete this car on my own. So far the only help I've had is a friend helped me set the body on twice. I am not going for a show piece just a 50/50 car. Looks good at 50 feet and 50mph.
  39. Likes JimLev liked this post
  40. #346
    Jun 2020
    SoDak
    Hi HVACMAN
    There isn't really one complete system / kit out there you kind of need to piece meal it together, so I pieced it together and order through Amazon....here is what I ordered
    3M 26000 PPS 2.0 Spray Gun Cup, Lids and Liners Kit, Standard, 200-Micron Filter, 22 Ounces= https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
    3M PPS (Original Series) 16124 PPS H/O Pressure Cup with Air Hose, Large, 28 oz, 1 Pack = https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
    3M 26003 PPS 2.0 Spray Gun Adapter 16 mm Female, 1.5 mm Thread, 1 Pack (Fits the Fuji T75G spray gun) = https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
    I am in the same boat as you, I'm going to finish this thing from start to finish on my own, only needed my kid's help so far to take the body off when the kit was first delivered and then to put the body on to start the body work, everything else was done with my own hands. I've done other restorations, so painting I'm familiar with, but I'm not going for a show car mirror finish but my hopes are it will turn out as good as some of my other vehicles and will be a nice finish but the purist may pick it apart but then you just ask to see their work and they walk away normally.
    Funny story, I did a car show last summer with my 70 Challenger and it's a nice looking car (pic attached) but not perfect by any means (I still need to do a good cut & buff on it) and the majority of the folks liked it, I actually took home an award for my class but this one joker was there about 45 minutes just walking around / ripping on it saying this is wrong, or he wouldn't have done that, etc., etc., as well correcting other's comments who were looking at it and finally I got sick of it and walked up to him and said 'let's go over and see your 70 Challenger", and the guy paused, looked stunned and finally said "what.......I don't have one" and quietly walked away. I'm fine with folks who own cars critiquing other's cars to a point, but if you don't own one and your ripping someone else car apart, just shut up.
    And as a disclaimer to my comment above about doing it myself, I completely understand some folks can't or don't want to, so I am by no means saying that is wrong or ripping someone for taking that approach, to each their own is my opinion. Building it partially or building fully is still a huge deal and one we should all be proud of.
    Jim
  41. Thanks HVACMAN thanked for this post
    Likes narly1, McGuyver, FF33rod, RoadRacer, HVACMAN liked this post
  42. #347
    Jun 2020
    SoDak
    • 1.8 for epoxy
    • 1.3 for paint
    • .8 for clear
    Jim
    By the way, HVACMAN, always ask for the TDS (Technical Data Sheet) for the epoxy sealer, primer, paint & clear you buy which provides mixing instructions, flash times, and most importantly tip ranges to use. The containers usually have some info but definitely not all you need.
    Some suppliers don't have hard copies of the TDS but you should be able to find them online.
    Jim
  43. Thanks HVACMAN thanked for this post
    Likes HVACMAN liked this post
  44. #348
    Jun 2020
    SoDak
    Finished prepping the door jams (more work than I thought), trunk jam and the inside of the trunk for primer. I just have the insides of the doors left and then another huge milestone of prepping 100% of the body is complete.
    Jim
  45. Likes FF33rod, narly1, HVACMAN liked this post
  46. #349
    Pretty incredible. The cars look so completely different when they go through body prep. Kudos
  47. Thanks 33fromSD thanked for this post
  48. #350
    Sep 2019
    Hi HVACMAN
    Perfect response. I gotta remember this! Nice Challenger and Mustang. What size are the wheels on the Challenger? I like them not too big or too small. As someone who started driving in the 70s, muscle cars with large wheels do not look right to me.
    Andy
    33 Hot Rod with Deluxe Grill (32) Hood & sides, Bike Fenders, Hard Top, AC, Power Windows, Electric Power Steering, 306 Ford Small Block - roller cam, aluminum heads, Eldenbrock intake & carb, T5, Moser 3 link, Arrived 5/6/20.
  49. #351
    Sep 2019
    Jim,
    When you go to paint are you going to remove the body or leave it on the chassis?
    I'm a long ways from painting, but find myslef thinking about this a lot. This will also be my first time painting a full car.
    Doing a lot of reading on body prep and painting when I'm not in the barn.
    Andy
  50. Likes HVACMAN liked this post
  51. #352
    Jun 2020
    SoDak
    Quote Originally Posted by e36m3 View Post
    Jim,
    Andy
    Hi Andy
    I'm priming it as you see it (body on), once final sanding after priming is done, then I'll paint / clear the jams, cowl area, inner hood, inner trunk, inner doors, belly pan, lower portions of the engine covers, inner edges of the front fender and reassemble everything, then paint / clear the whole body in one shot.
    It's not for everyone, but this is how I do all my cars. I like painting the panels on the car for a couple reasons:
    1) I can guarantee the spray orientation on each panel is the same (yes I know this can be done off the car too if you're careful
    2) The way I do it, I don't have to worry about scratching freshly painted individual panels (doors, hood, trunk, engine side panels, etc) when reinstalling them after painting off the car.
    Has always worked for me, it's just how I do it.
    Jim
  52. Likes HVACMAN liked this post
  53. #353
    Jun 2020
    SoDak
    Andy
    Thanks Andy
    The wheels on the 70 Challenger are American Racing Magnum style wheels to mimic the stock versions (A lot of folks if not paying attention think they are stock), they are 15"x7 in the front and 15"x8 in the back, I can't recall tire size off hand besides the fronts are 60's and the rears are 55's but like you said they are not too big, but just right for the car. The stock magnum rims are 14x5....so tiny & skinny, just didn't look right.
    Jim
  54. #354
    Jun 2018
    I remember when 55s and 60s looked crazy, real muscle! LOL
  55. #355
    Jun 2020
    SoDak
    Yup...compared to the 35s I have on the rear of the 33 HR, the 55s & 60s on the challenger look like racing slicks.
    Jim
  56. Likes FF33rod liked this post
  57. #356
    Hi HVACMAN
    Jim
    Thanks for all the information Jim. Sorry about the rookie questions. I held an ASE Master Certification for years, before switching to HVAC in the 90's, but no experience with paint and body.
    The Challenger was one of my favorite MOPAR's in the 70's and yours is a very nice example. Why is it there is always one of "those guys" at every car show. It takes an equal amount of time to compliment someone's accomplishments and usually with a better outcome.
    Thanks again
    Andy
  58. #357
    Jun 2020
    SoDak
    Thanks again
    Andy
    No worries at all Andy, we are all here to help and learn from each other. I'm always learning from everyone on here.
    I used to do a ton of car shows with our toys but I only do a few now due to those one or two people who do noting but try to be know it alls.....just takes the fun away.
    Yeah, I've alway loved the 70 Challenger.....I bought a new Sublilme Green 2015 Challenger Scat pack in 2015 and after that I knew I needed a 70 since the new style Challengers were designed after the 70. Couldn't find one in decent complete shape without spending big $$$, and then I ran into a woman who husband died and was in the middle of restoring this one. All the metal work was done and in primer stage, just needed paint, top, trim, interior, and power train. Took a solid year going through it and fixing it up.
    I get quite a few looks / folks physically stopping on the street to look when I have them both parked in our driveway at home. Here's a shot of them at our storage garage.
    Jim
  59. Likes JimLev, FF33rod, RoadRacer, HVACMAN liked this post
  60. #358
    Jun 2018
    Gorgeous Jim!
    Love Mopars
  61. Thanks 33fromSD thanked for this post
  62. #359
    Jun 2020
    SoDak
    Big milestone met, inner doors are now prepped which completes 100% of the body being prepped for primer. I just need to go through all the panels with filler on them with a super bright light checking for pin holes in the body filler before I prime. Should be able to get through that relatively quickly tonight / tomorrow morning. Still hoping to prime tomorrow.
    My 3M PPS 2.0 kit arrived today which should compliment the Fuji Spray system nicely.......I can't wait to try that out.
    Then all that is left is to clean up the garage, mask it off and start priming.
    Drivers Door:
    Passenger Door:
    Jim
  63. Likes HVACMAN liked this post
  64. #360
    Jun 2020
    SoDak
    Priming done....I'm going to let it sit a couple days and then start the ever so fun task of final sanding.
    Jim
  65. Likes FF33rod, RoadRacer, HVACMAN liked this post
