Results 1 to 12 of 12
Thread: Cobra Seat Warmer
    Aug 2020
    Cobra Seat Warmer
    All,
    I’ve called the vendor but no response.
    Does anyone what you can and cannot trim on the seat warmers? I don’t want to ruin them by cutting the wrong thing...
    For the back of the seat is any trimming required?
    Thanks in advance
    Jan 2020
    State of Jefferson
    I used Forte's seat heaters and did not need to trim anything off for the back and lower seat cushions
    https://fortesparts.com/product/cobr...proof-regular/
    Feb 2020
    Chicago
    you don't need to trim anything at all.
    Dec 2018
    Hudsonville, MI
    I recall trimming in one direction to shorten them but I would consult the instruction sheet provided. If you don’t have them I can send a copy of it later this evening that details what trimming is acceptable.
    Coupe Kit Delivered 11/10/23
    Cape Coral, FL
    Are you installing the ones from Cobra Heat? WarmSeats is the trademark name. Their instructions say they can be shortened length ways but never cut to reduce the width. "Never cut the areas covered with adhesive tape". Elements are 11 inches wide and step 3 shows where they can be cut.
    FYI I did not need to cut mine. Went in no problem.
    2nd MK4 #10639 received 3-19-23. Wife's version. Street Snake - IRS, Willwoods, no roll bars, no hood scoop, no stripes, Blue Print Sniper 2, 302 with 4R70w trans, and under car exhaust. McLaren Racing Green with saddle leather interior.
    1st build - Mk4 Roadster #9319, received 4-10-18. IL registration 8/6/19. Moser 8.8. 3 Link. Wilwood brakes. Blue Print 427, Holley 750, TKO 600, 0.64 OD. Paint Dec 2020. Ruby Red with Carbon Flash Black metallic stripes.
    No trimming required on my install. The bottom pad does roll over the front seat foam.
    These are the heaters I used: http://www.cobraheat.com/WarmSeats-W...ater-_p_9.html
    Aug 2020
    Cobra Seat Warmers
    I have the Cobraheat Seat warmer just like the link...
    Ok — I see how you installed the bottom without trimming - I’ll do that!!
    How did you install the back of the seat - did you stuff it up or take everything part?
    Matt
    Quote Originally Posted by Padawan View Post
    Matt
    I just stuffed it in after opening up the cover at the bottom edge:
    Aug 2020
    All,
    I got into the seats last night...the install seems like a breeze. Last quick question... The Waterproof Cobra Seat warms only came with one adhesive tab in each seat kit...where did you use the adhesive tab? Rear of the seat? or Bottom?
    Matt
    All,
    Matt
    If you're talking about the foil stuff that came with them, I think that is only used if you trim the pads.
    St. Helena Island, SC
    I didn't use the adhesive tabs. The heating elements have stayed put without them.
    TMartinLVNV's Avatar
    Jun 2019
    Las Vegas, NV
    I have the Kirkey seats and had to trim down the pads. I think that I cut about 1/3 of them off. Just cut across them, not up/down. I used the same spray glue for the carpets to hold the pads in place. They haven't moved at all.
