Actually you need to keep the outer axle stub that goes back into the front spindle knuckle, and this gets bolted back into the hub with the large 32 mm nut. This is how the hub and bearings are retained on the knuckle.
818 "S"pyder delivered 11/27/20, using 2007 Impreza 2.5l NA donor.
MK3.1 #6583RD, built from 2008-2010, sold 11/2011
