Originally Posted by
mcamera
Anybody know what size and grade bolt goes in the lower hole, of the front spindle to upper ball joint bracket? FFR supplies a 10.9 / M16 bolt for the upper hole and says to use the OEM strut mount bolt/nut for the lower hole. I'm missing the OEM hardware for the lower hole. I bought 8.8 / M14 hardware and now I'm second guessing myself if I should buy 10.9?
This is what I bought from Belmetric
12 x WFHV16 - Hardened Flat Washer (WFHV16) = $6.12
4 x BH16X1.5X40 - Hex bolt 10.9 (BH16X1.5X40) = $18.24
12 x NNH16X1.5 - Class 10 Nylock (NNH16X1.5) = $15.36
12 x NNH14X1.5 - Class 10 Nylock (NNH14X1.5) = $16.32
4 x BH14X1.5X60 - Hex bolt 10.9 (BH14X1.5X60) = $18.96
4 x BH16X1.5X65 - Hex bolt 10.9 (BH16X1.5X65) = $19.52
I was buying for 2 cars and the LCA mount bolts. So you may need to adjust your quantities.
