EDIT: New #1: no donor, but I'm not sure how common that is nowadays.
1. Better tires from day 1. I purchased the least expensive tires just to get on the road. At the time they were Sumitomo HTR. Good tires are a safety issue.
2. Clear bra on the front nose, even if just a spray-on bra like 3M Paint defender. The nose chips up MUCH faster than you'd ever imagine!
3. Wiring harness from a supporting vendor or Factory Five. I used a generic "street rod" wiring harness. The turn signals were tough since the FFR does not have a "standard" steering column with signal stalk.
4. GPS Speedo. My speedo is in the middle and due to the speedo cable taking weird turns, it has proven impossible to get the needle to not "dance" below 30mph. Although then this would mean digital odometer
Hyde thanked for this post
