Thanks Thanks:  84
Likes Likes:  481
Page 4 of 18 FirstFirst ... 2345614 ... LastLast
Results 121 to 160 of 685
Thread: 25th MKIV #9772 Build NOR*CAL: new vanity plate
  1. #121
    Ottawa, Canada
    Hi Todd,
    I am enjoying watching this build come along. I am curious about the Boyd Tank, it looks great tucked up in the frame. Would you have any pics from the back at level of the tank, and from the side, just to see how low is sits in relation to the frame. Would be much appreciated as I was considering a Boyd tank for my build when I get to that point as my plans include the 390 and the extra fuel capacity would be a big bonus.
    Great Build!!
    Thanks!!
    Achi
    Mark IV FFR 7993 picked up March 30, 2013
    Pin drive IRS, 390FE, Smiths gauges. going to be a long slow build.
  2. #122
    Folsom, CA
    I was thinking the same thing when looking at the pics. No access to those cap bolts once everything's together. Obviously hope to not have to drop the tank. But it could happen. I'd consider just making them permanent, e.g. a tack weld to the frame. Or some other method making access to the top unnecessary. One other suggestion. You may want to just cut off those rear tank strap tabs. Especially the RH side where they protrude into the trunk.
    yep, i'm trying to determine how to match the paint color if i cut the trunk tabs off...
    Quote Originally Posted by achi View Post
    Hi Todd,
    Great Build!!
    your wish is my command!
    as you can see I could have put the rear tab 'above' the rear chassis rail and moved the tank up 3/4" overall - and there is room to do that - but I also have about 2" of depth from the top of the trunk bars to the top of the tank - so I can do some drop trunk magic - if nothing else it will keep some smaller things from rolling all around the trunk
    Todd
  3. #123
    High Desert, CA
    Mr toadster
    I noticed in your latest pic that you have a rag stuffed in the inlet. I did that also the baggie thing but did you
    know that a black ABS rubber cap fits perfect. I didn't trust my self that something wouldn't fall in. You don't
    need to use the clamp just the cap. Don't mean to pick on your build I enjoy your buildmanship just looking
    out for you.
    MKIV 8851 Complete LS3 376/480 4L70e Auto 2015 IRS 15" Wheels Rear Exhaust
    Ordered 2/25/16 Delivered 3/26/16 Still building 1/1/22
  4. #124
    Folsom, CA
    Quote Originally Posted by Lancaster Lad View Post
    Mr toadster
    out for you.
    yeah, I hear you - I forgot to keep the cap covers that Boyd shipped with the tank - so I improvise, will probably find a cap like you stated to be a little more sturdy
    edit: ok - i cheaped out and just used some tape
    Todd
  5. #125
    Ottawa, Canada
    Hello Todd,
    Thank you very much for the pics!!
    It fits like a glove in there. Very nice and sturdy unit.
    Achi
  6. #126
    Quote Originally Posted by toadster View Post
    LH side is 100% covered by the trunk aluminum. Impossible to see once everything is together. You will need to add a small patch piece on the aluminum. RH side would still be visible, but only from the bottom and behind the tank. I'm as anal as anyone, but any color even close will be unnoticeable IMO. I may have posted this before. But https://www.lvppaints.com/ will provide paint that matches your powder coat. Used them on my 20th Anniversary build and it's excellent. They can match if you know the exact powder coat mfg and color. Or they can match to a physical sample.
  7. #127
    High Desert, CA
    Sorry to bother you but I just checked my frame to tank clearance.
    I have 1 3/4 tight or about 1 1/2 deep area for cubby.
    Did you look at the upper trunk area between the diff and the tank?
    I don't know who to give credit to but some one took that space for storage.
    There is at least 7in deep and over 24in wide. Could also be larger with a
    stepped bottom. Don't know where your battery is going, I going up front
    with Breeze tray.
    The new powder coat color is growing on me.
    Thank you for sharing your build with us.
  8. #128
    Folsom, CA
    I have a piece of the chassis that I cut to do the brake booster so I'm going to take to a local shop to see if I can color match it...
    The feedback from Factory Five (Tony Z) is that the color is Anodized Medium Bronze Matte by Powder Buy the Pound
    Attachment 130096
    I have 1 3/4 tight or about 1 1/2 deep area for cubby. Did you look at the upper trunk area between the diff and the tank?
    I don't know who to give credit to but some one took that space for storage. There is at least 7in deep and over 24in wide. Could also be larger with a
    stepped bottom. Don't know where your battery is going, I going up front with Breeze tray. The new powder coat color is growing on me.
    I have the breeze battery tray as well, its at the powder coater - just doing black to match the engine bay.
    Yes, there is a lot of 'air space' behind the tank and back wall - my one friend opened that whole section above the rear seats and it's rather spacious.
    Another idea is to mount the estopp system in there - like JohnK did https://thefactoryfiveforum.com/show...l=1#post415574
    Todd
  9. #129
    What is the capacity of that tank? Nice work by the way.
  10. Likes toadster liked this post
  11. #130
    Folsom, CA
    Quote Originally Posted by Straversi View Post
    online they say 20 gallons, but others on here have said anywhere from 24-26 - pretty substantial!
    Thanks!
    Todd
  12. #131
    May 2020
    Toadster,
    I too, am in Folsom, and have also placed an order for A Mk4 Roadster from FFR.
    will you send me an email to Rat2274@msn.com and I will share more details.
    I would love to talk builds with you.
    Rat2274
  13. Thanks toadster thanked for this post
  14. #132
    Folsom, CA
    Quote Originally Posted by Rat2274 View Post
    Toadster,
    Rat2274
    absolutely anytime! will email...
    Todd
  15. #133
    Folsom, CA
    it's been a long couple of weeks, lots of 'work' getting in the way of the car- but that's life!
    I started pulling together the radiator setup, and it takes a decent amount of prep-work to get things together.
    Since I'm using the Breeze radiator shroud, upper hinge and lower mount there is one small adjustment needed - trimming the 3/4" segments that are connected to the upper 3/4" cross-bar
    since the bronze color is unique on this frame, I tried to match it closely - not that it will really ever be seen. upon initial spray it looks 'close' but when you overlay it on top - it's still too light...
    not something I want to spend $120 minimum on for color matched paint... at least it's protected
    the next parts just require a bunch of holes, 14 across the top radiator tab front, and 2 in the rear top tab that align with the support bolts.
    got late last night, so I was able to line things up and clamp into place - still need the lower mount installed and adjust to 58-degrees (will be using the replicaparts radiator panel)
    still a bit puzzled how the top hinge connects to the 3/4" bar - there are 4 bolts with lock washers, but nothing for the bolts to 'grab' like a nut?
    I already rivnut'ed the shroud, so that will hold the fan in place.
    added 4 rivnuts for the top hinge and mounted the fan tonight
    I'll run the brake lines before I final mount this part.
    Todd
  16. Likes Fman liked this post
  17. #134
    Folsom, CA
    Slow goin this week, also working on installing pergo in my office (too many projects!)
    finally mounted the rad after fitting up the FFR panels, the ReplicaParts panel cost more to ship than the part costs
    752CF3E8-83A8-4DFF-9D26-F66AEC456EF4.jpeg F8A541D9-42D8-42BB-9A24-7726FB7C98FA.jpeg
    Todd
  18. #135
    Feb 2020
    Chicago
    Looking good buddy!
  19. Likes toadster liked this post
  20. #136
    Folsom, CA
    cleaned up a few items yesterday that have been putting off...
    installed more Thermo-Tec on the FF Metal firewall, maybe overkill but would be impossible later without a teardown...
    will definitely be buying a few more rolls of this stuff to get everything covered, 2 rolls isn't nearly enough
    my ABS sensors (Motorcraft BRAB-406) arrived after I had the rear brakes installed, and those sensors are long and too stiff to place (see 1st pic) with the rear bracket installed
    had to undo the parking brake, rotor, caliper and loosen the bracket to install (I'm getting good at rebuilding!) you can see in the 3rd pic below how the bracket and wire are aligned, hence he teardown/rebuild
    Next was to installed the breeze battery tray. I love Mike's stuff but I wasn't too keen on screwing a bolt into the 4" rail with no backing, so I opted to install an M8 nutsert instead
    This was a funny story as I started getting the holes prepped and the one closest to the side is pretty tight and as I was compressing the nutsert, I was stuck against either the cross-bar or the jack stand
    Hence, I had to jack the car up, replace the jack stand further back and then proceed... I nutsert was mangled in this process but once reset; the new one fit great!
    This battery tray isn't going anywhere! and BTW if you don't have an air-rivet gun - GET ONE, seriously it's so effortless to set and shoot rivets!
    next up will most likely be to drill out the rest of my sheetmetal, waiting for my rivet-fan to arrive so I can lay out better lines!
    Aircraft Tool Supply Rivet Fan Spacing Tool
    Todd
  21. Likes Fman liked this post
  22. #137
    Nov 2018
    Centennial, CO
    Nice work so far. I can tell you that 4 rolls of the Thermo-Tec will do the entire cockpit and then some. However, you have to use your big scrap prices too.
    Bradley
  23. Likes toadster liked this post
  24. #138
    Folsom, CA
    Quote Originally Posted by GTBradley View Post
    Thanks! That's what I've realized as well. Can't really over-do it with this stuff it lays out so easily and yes, I use all my scraps in all the places you never will see
    Todd
  25. Likes GTBradley liked this post
  26. #139
    Folsom, CA
    Cool
    Made more progress today on the driver footbox. Initially i was a bit puzzled on the kick-out panel, but Travis (Fman) helped with some pics of his setup
    One of the issues of the 25th anniversary car is that the panels didn't come pre-staged on the chassis, just 2 boxes of panels and lots of guesswork!
    I have to say, whoever developed clecos - I pray he's a rich man, because these things are awesome! I can't imagine building without them to be honest!
    61629121187__817E1F89-14A5-4071-AC2D-D153206D2A8B.JPG IMG_0808.jpg IMG_0813.jpg
    aligning all the panels is pretty tricky, plus I had to notch the small front panel to make room for the nut/bolt setup for the Whitby brake brace
    overall, pretty happy with the progress... it was 88F in the garage and that was with my portable A/C blasting - better than the 102F outside for sure!
    Todd
  27. #140
    Folsom, CA
    some more fun drilling holes last night... you don't realize how many holes are in this car until you're 2 hours into it and there's a lot more to go!
    I'll most likely keep things cleco'ed in place until I know I'm done working around that section...
    still need to figure out the mini drop trunk ideas and will have to change the locations for the pump and sender holes as well
    Todd
  28. #141
    My brother came down to visit and we drilled, sanded, clear coated and riveted panels for three days. We had a good time working together and the time flew by, but man, was I happy to have had help on that project. Your project is looking good!
  29. Likes toadster liked this post
  30. #142
    Apr 2020
    Virginia
    Toadster,
    I’m also a big fan of cleco’s, which are totally ingenious, and I wondered who actually invented them. Apparently, the “cleco” tool was originally commercialized the Cleveland Pneumatic Tool Company. So, Cleveland . . . Co . . . = “CLECO.” I imagine this tool really came in handy for aircraft production during WWII.
    The Cleveland Pneumatic Tool Company filed a patent in 1941 for this tool, which looks a lot like a cleco tool: https://patents.google.com/patent/US...=2%2c328%2c866
    If we are to give these inventors full credit for the cleco, then that credit belongs to Paul Van Sittert and Andrew J. Lev, who were employees of the Cleveland Pneumatic Tool Co. at the outbreak of WWII.
    I would note, however, that a French citizen, Mr. Jean J. Blanc, invented something strikingly similar in 1936: https://patents.google.com/patent/US2328866?oq=2136875
    I’ll leave it to historians to figure out who the “true” cleco inventor is. But I agree it’s a great tool!
    BTW, I'm a patent attorney, hence my weird obsession with who invented what.
    MKIV Complete Kit #9822 l BluePrint 347 EFI l TKO600 l Power Steering l Heater/Defrost l Build Thread
  31. Thanks GTBradley thanked for this post
  32. #143
    Folsom, CA
    started the fuel lines yesterday... I have fragola PTFE lines and AN fittings, an Earl's and Russell setup for the in-tank pump
    Attachment 132606 Attachment 132605 Attachment 132602 Attachment 132603 Attachment 132604 Attachment 132635
    initial cut was with tin snips LOL - yeah that wasn't good
    2nd cut was with a hacksaw with a fine tooth blade - if the ends are taped up good - it's not a bad solution
    3rd cut was with a dremel and cutoff wheel - was easy but dusty!
    2ft done, about 12 more to go!
    Todd
  33. Likes Fman liked this post
  34. #144
    Folsom, CA
    drilled about 350 holes tonight... geesh! when does it stop!? LOL
    080220.jpg IMG_0950.jpg IMG_0951.jpg IMG_0952.jpg IMG_0953.jpg IMG_0954.jpg IMG_0956.jpg IMG_0957.jpg
    did more sound/heat deadener too
    Todd
  35. #145
    Sep 2018
    SF Bay Area, CA
    Hahaha - hang in there... it eventually ends.
    I spent what seemed like an eternity drilling holes. When I finally finished I spent an entire afternoon with the shop vac cleaning the garage. I'm so glad that phase is over.
  36. #146
    Jan 2020
    State of Jefferson
    Todd, would you mind to put some links on what you ordered from Summit? (fuel filter, fittings, amount of line) I notice you have some type of jig/wrench to attach the -AN fittings? I am going to latch on to your fuel line solutions, assuming you are going to run the Fragola lines all way to engine with no hard lines?
    Keep 'er up! Builds looking great!
  37. Likes toadster liked this post
  38. #147
    Feb 2019
    Greality, Colorado
    Hahaha. Yeah, I got a good chuckle off that! How many licks to the center of a tootsie pop? That silly but very pondering commercial we all loved. It's time that we update it.
    Mr Todd, how many holes drilled to the completion of one's dream? I'm starting to think the builder might not know either, since I've already lost count myself. So, I guess it is true?! The world may never know...
    Build is looking good and you're way ahead of me. Keep at it!
    Dj
  39. Likes toadster liked this post
  40. #148
    Folsom, CA
    Quote Originally Posted by ydousurf View Post
    Dj
    Thanks Dj! LOL, yeah there is SO much more to drill!!!
    Quote Originally Posted by Fman View Post
    Thanks Travis!
    Here's my list from Summit
    Part Number Item Price Qty Total
    AEI-15606 FITTING $14.06 3 $42.18
    AER-FCM3661 Aluminum Vise Jaw Inserts $34.99 1 $34.99
    FRA-600106 STR HOSE END $10.99 6 $65.94
    FRA-602006 TEFLON HOSE 20 FT $82.99 1 $82.99
    SUM-900106 #6 AN WRENCH 11/16 HEX $9.99 1 $9.99
    you may want to play with end-types - I initially got all straight end connectors - but they're not too bad price wise to switch as needed.
    Todd
  41. #149
    Jan 2020
    State of Jefferson
    Thanks Travis!
    Thank you! Mucho appreciated!
    Do you have a link for the fuel filter? I like your style you are using much better, assuming it would work fine with my 427/EFI setup as well?
  42. #150
    Folsom, CA
    The Aeromotive setup I have is nice, it's a bit tight though, will have to disconnect both ends and push the filter up to unmount
    the 10 micron is perfect for EFI setup
    my setup is the Aeromotive 12347 Filter, In-Line, 10-Micron Fabric Element, 2" OD
    with the Aeromotive 12701 Filter Mounting Bracket, Black Spring Steel, Rubber Coated
    If i changed the build, I'd most likely use
    Aeromotive 12317 Filter, Canister, 10-Micron Fabric Element, 3/8" NPT Port, Bright-Dip Red Top/Black Cup, SS Series
    because the mount stays put and you simply unscrew/drop the filter, no disconnecting needed
    Todd
  43. Thanks Fman thanked for this post
  44. #151
    Folsom, CA
    finally pulled the trigger on the Wilwood EPBs, I got a better deal going through Jegs, versus Summit Racing as Jegs has a $30 off over $750 deal and the taxes were about 1/2 of Summit Racing... came to just over $1k
    in typical guy fashion, no directions - and I lined up the caliper and sighed, awww crud they interact with the springs
    so, I prayed the directions would tell me differently...
    EPB CALIPER - Mount the EPB calipers per the installation instructions included with your specific Wilwood brake kit, reference
    Figure 3. EPB calipers are left and right handed, however they can be used on either side of the vehicle to best suit your specific
    application.
    light bulb turned on, there is an offset that changes side to side , so I swapped sides - voila! They fit! They're close, but should have no issues!
    here's both sides mounted - the new EPB calipers have 'wilwood' printed on them where the regular ones were blank...
    sorry for all the dust, shows you how much ash got into the garage the past few weeks with all the CA fires this month...
    Todd
  45. Likes Fman liked this post
  46. #152
    So those are electric parking brakes?? I wonder if it's a universal kit. Gotta check that out, very cool!
  47. Likes toadster liked this post
  48. #153
    Folsom, CA
    yep! just electric wires, no cables!
    the Kit i ordered that fits the .81" rotors is 950-140-15978-BK
    if you want Red it will be 950-140-15978-RD
    Todd
  49. #154
    Sep 2018
    SF Bay Area, CA
    That's awesome! Thanks for being the trailblazer on that. Definitely looks like an easier and cleaner install than the E-Stopp, and by the time I factor in what I spent to make my custom mounting tray and custom parking brake cables for the E-Stopp, the Wilwoods aren't that much more expensive. What else did they come with in the way of a controller, switch, etc?
    The smoke and ash was also pretty bad here in the Bay Area the last couple of weeks. It's only been in the last couple of days that we've started getting good air quality again. All the cars are covered in ash, but I'm reluctant to wash them because that will guarantee another round of smoke and ash.
  50. Likes toadster liked this post
  51. #155
    Folsom, CA
    Quote Originally Posted by JohnK View Post
    the whole setup looks like this
    comes with the controller, wiring and a switch for the dash (or wherever)
    Todd
  52. Likes JohnK, JB in NOVA liked this post
  53. #156
    Jul 2019
    Midland tx
    Toadster,
    Your build is coming along pretty good.
  54. Likes toadster liked this post
  55. #157
    Folsom, CA
    man after a long break, back into it again...
    my son stopped over last night and we tackled the front ABS sensors which has been bugging me for a while
    The Russ Thompson ABS brackets are designed for the '95 ABS sensors but I have the '07-09 GT500 ABS setup so different sensors Motorcraft BRAB-290
    thankfully my son has better vision than me (LOL) and noticed that @johngeorge had drilled some new holes for these sensors!
    we pulled the ABS brackets and drilled a few holes and now the sensors are perfect!
    baby steps but progress!!!
    I ordered a bracket for my HCU since mine came without one - but I can't complain, the GT500 HCU was $15, and I found the bracket for $20 shipped LOL
    Next I'll be mounting the brake reservoirs and figuring out the placement of the HCU to run the brake lines.
    Todd
  56. #158
    Jan 2020
    State of Jefferson
    Back in the game! Looking good my friend, I commend you for your brake system that ABS is going to be awesome!
  57. Likes toadster liked this post
  58. #159
    Folsom, CA
    Finally getting back on the car... time to get fuel lines installed!
    I drilled and tapped 5 of 6 holes, last one in the engine bay will depend on FPR placement
    To get a measurement of how long of a run, I used some simple cord from home depot ~$4 on sale and trimmed/burnt the ends to keep from unravelling, taped from the filter to the engine bay
    I drilled out and set my Earl's dual line mounts, and got to the Fragola AN6 straight fittings...
    In order to mount the fittings, I had to get longer socket-head 1/4-20 screws - they fit perfectly into the frame!
    I also got the Fragola Hose Pressure Kit to test for air leaks, and I think both ends need re-doing...
    Yes, I need to get new olives since these are a 1 time use thing...
    Earl's 1/2" Hose & Tubing Separator Black https://amzn.to/3rfkQ04
    Earl's Performance AN to Straight Cut O-Ring Fittings AT949006ERL https://amzn.to/3p73SPz
    1/4-20 x 7/8" Socket Head Cap Screws, Allen Socket Drive, Stainless Steel 18-8, Full Thread, Bright Finish, Machine Thread
    https://amzn.to/34taK24
    Fragola FRG900666 Size (-6) Individual Hose Pressure Test Kit https://amzn.to/3atQOj9
    Todd
  59. #160
    Jan 2020
    State of Jefferson
    Todd, I found when using these AN fittings you need to push the olive flush against the vice to bottom them out on the hose before tightening down and using lube on the threads is a big help aiding in tightening them down. I also trimmed a little off the steel braid back around the olive nut before tightening them. Have you tried to tighten those fittings a little more before pulling them apart? Sometimes they need just a little more to complete the seal.
