good point a probably will add some small access holes for the 5/8ths Allen wrench on top - the front mounts should be easy to access
I was thinking the same thing when looking at the pics. No access to those cap bolts once everything's together. Obviously hope to not have to drop the tank. But it could happen. I'd consider just making them permanent, e.g. a tack weld to the frame. Or some other method making access to the top unnecessary. One other suggestion. You may want to just cut off those rear tank strap tabs. Especially the RH side where they protrude into the trunk.
