Likes Likes:  2
Thread: e-brake pulley config
    Folsom, CA
    Lightbulb e-brake pulley config
    to copy the folks who've mastered this mod
    https://www.sunshinegaragemkiv.com/c...ncy-brake.html
    https://thefactoryfiveforum.com/show...l=1#post106019
    https://thefactoryfiveforum.com/show...l=1#post225428
    I'm pulling together the common list of parts:
    1 x Alloy Steel Shoulder Screw 3/8" Shoulder Diameter, 2" Shoulder Length, 5/16"-18 Thread 91259A632
    2 x Pulley for Wire Rope for Horizontal Pull, with Bearing, for 1/4" Diameter, 1-3/4" OD 3434T24
    1 x High-Strength Steel Nylon-Insert Locknut Black Oxide, 5/16"-18 Thread Size 97135A416
    still struggling to find the Lokar brake clevis (Lok-S-8078) by itself...
    other options to keep in mind? I believe many are 'extending' the lower arm to help the clevis clear the frame rail
    Todd
    Nov 2019
    Charlotte, NC
    I did the 2" shoulder bolt without the washers. Call Lokar, their response below:
    "Not discontinued but no longer available through our dealers. You can contact us and we’ll be happy to help you with that. Retail price is $33.17"
    Marty Waterstraut
    Technical/Sales Representative
    877-469-7440 x8925
  3. Likes toadster liked this post
    Folsom, CA
    Quote Originally Posted by BradCraig View Post
    Marty Waterstraut
    877-469-7440 x8925
    Thanks Marty! I guess 2" would be enough as the pulleys aren't really doing much rotation and don't need the spacing..
    I'll give Lokar a call! Thanks!
    Todd
    Nov 2018
    Centennial, CO
    Well the Lokar C]clevis is now out. I tried to obtain it from Lokar and here is their final response regarding S-8078:
    Bradley,
    You’re welcome. Those small parts were previously available through our dealers. At the first of this year we stopped those sales. Let me know if you have any other questions.
    Thank You
    Chris M.
    Technical Support Specialist
    Lokar Performance Products, Inc.
    2545 Quality Lane
    Knoxville Tn. 37931
    Toll Free: 1.877.469.7440, Ext. 8924
    Email:
    chrism@lokar.com
    Web:
    www.lokar.com
    Bradley
    Nov 2019
    Charlotte, NC
    Quote Originally Posted by GTBradley View Post
    Bradley,
    Thank You
    Chris M.
    2545 Quality Lane
    Knoxville Tn. 37931
    Email:
    chrism@lokar.com
    Web:
    www.lokar.com
    See my post above. They indicated the same, but also stated they will sell direct to you. Hopefully they haven't discontinued entirely
    Sep 2019
    Bothell, WA
    I was able to find just the block that clamps down on the 2 cables at Speedway Motors. Lokar #S-8070 $16.99. Might get you closer to what you need.
    Santa Clarita, CA.
    I did not care for the FFR brake handle so I opted for the stock mustang park brake handle along with the pulley idea to keep the cables off the frame. We tried the Lokar block clamp at first but the cable started to fray and we were not happy with the end result.
    For our application we decided that cutting the cable to the proper length and having threaded ends swagged on made for the cleanest install. We used a local sail boat shop to install the ends and I think the end result is perfect. The block in the photo I made and allows for some adjustment. I also made the block to secure the pulley to the park brake assembly.
    F5R #7841: 15th Anniversary Edition MK4, Ford Racing Z427, Holley Terminator X Stealth EFI, Gas-N Pipes, Stainless Headers, Liberty's Gears TKO600, 3.31 Moser 3-Link, 17" Halibrands
  9. Likes toadster liked this post
  10. #8
    Jan 2020
    State of Jefferson
    Quote Originally Posted by CDXXVII View Post
    Would you mind posting some links where you bought all the components for this mod? What was the reason you went with the Mustang brake handle over the FFR?
  11. #9
    Southport, NC
    I have just finished my emergency brake modifications and am happy with the results. I did not like the cables going under the chassis.
    I've got a very early Mk4 that came with the Ford Emergency Brake handle standard. I am very happy with it but to buy it is very expensive, I believe over $200. The large diameter pulley on this unit sets the cable a little lower toward the bottom of the car. Just enough to make it work for what I did. I've seen the modifications of others with the pulleys set up mounted to the frame and was going to do this myself. However, when I started getting into it, I found a better way without the pulleys.
    Note in this picture how I put everything together. I bought a longer 1/8” cable with a 3/8” barrel end to mount to the Ford emergency brake pulley. The supplied set up was just not going to work as it had too much in the way of the frame members. To the other end, I attached a Sta-Loc Eye – 1/8” which I could hook up to the Lokar hook up I’ve holding up with my hand. It used to be available by itself but now you can only get it together with cables.
    IMG_8930 by George Ligon, on Flickr
    On the other end of the cable, I added a 1/8” Sta-Loc Eye. It’s in the red circle
    IMG_8917_LI by George Ligon, on Flickr
    This shot is from above looking down through the trans tunnel.
    IMG_8919 by George Ligon, on Flickr
    This is link to the Sta-Loc site: https://www.stalok.com/product/sta-lok-eye-inch
    I did have to cut a bracket out of the way that was just behind the Brake Handle which, at one time, was probably another way of setting up the emergency brakes.
    George
