Likes Likes:  3
Results 1 to 25 of 25
Thread: INstalling Gen 1 Coyote in MK3
    Jul 2019
    North Carolina
    We are rebuilding MK3 Cobra. I purchased a Gen 1 Coyote engine and the Cobra jet intake. I'm a little worried its not going to fit. We are not quite ready to drop the engine in yet so I was wondering if anyone had experience with this before we get started. Will it fit? Are there any modifications needed to make it fit? It looks to be close.
    Port Charlotte, FL
    J,
    What motor is coming out of the car? The reason I ask is the drivers footbox may need updating. If it’s a 302 or 351, chances are it will. If it’s a 4.6, you should be good.
    Henry
  3. Likes JWolfe liked this post
    I just swapped a 347 to a coyote gen2 in a mk4. I had to buy the left foot box aluminum..it has a step in it to clear the left rear of the engine. I don’t know if it’s the same as your car but a call to FFR will clear it up. Good luck it’s a fairly major change
    MKIV with Coyote and TKO500
    2013 Boss Mustang
    2015 50th Anniversary Mustang
    1968 Mustang
    1951 Ford F1
  5. Likes JWolfe liked this post
  6. #4
    Jul 2019
    North Carolina
    It was a 302 out of a '91 mustang gt. The footbox and panels are all being replaced. I bought the car with supposedly only 4 miles on it. I'm no mechanic but a friend of mine is and I should have had him look at it before I bought it. The car is a mess. The dyno said the 302 was only pushing out 186 hp. I was told it was a fresh rebuild with a TKO500 tranny. Neither of these were true. My friend told me I was better off buying a new MK4 kit and starting over. But I'm already invested in this one. Completely new wiring and everything has to be done. My friend works on a race team- said I was lucky I didn't catch fire in the 2600 miles I drove it. Thanks for the input.
  7. #5
    Jul 2019
    North Carolina
    Jul 2019
    North Carolina
    Macedon, NY
    looks like a fun project. the coyote will fit in there but call F5 about panels. They should still be able to make them if needed. Go get the engine and test fit it in there
    stack
    FFR MKI Roadster FFR2202K Built in 2000 sold
    FFR Hot Rod #39 under construction
  10. #8
    Oct 2017
    I put a Gen II Coyote in a MK III with no issues. Used the correct engine mounts and replaced driver's side footbox panels.
  11. #9
    Jul 2019
    North Carolina
    We have all the mounts and panels. Just unsure about the height. The Cobra jet intake sits high up on the engine
  12. #10
    Heart of Dixie, Alabama
    I have the CJ intake on a Coyote, but in a Mk IV frame. The intake was clearing the hood, but has started to rub slightly.
    I am still in gel coat and not for sure the body is high, low or in between. I put a piece of peel and stick foam on the bottom of the hood. Also, if I cut the hood for the scoop it is a non issue.
    Hope this helps.
  13. Thanks JWolfe thanked for this post
  14. #11
    Jul 2019
    North Carolina
    Yeah, I was thinking the hood may need some "adjusting". We are going to find out today as the engine is getting dropped in.
    Thank you!
  15. #12
    Jul 2019
    North Carolina
    Jul 2019
    North Carolina
    Show me some pics of your engine. Glad everything fit so well.
  18. #15
    Jul 2019
    North Carolina
    It's in my friends shop who is on vacation. I'll get a couple next week
  19. #16
    Jul 2019
    North Carolina
    Jul 2019
    North Carolina
    Jul 2019
    North Carolina
    I don't know why they turned in the upload
  22. #19
    Quote Originally Posted by JWolfe View Post
    Is your mass air sensor in the big aluminum tube coming off the throttle body.
    I do not know if tuning will be an issue in that large of an intake tube?
    If you have had it running already, I guess not.
    My intake filter is behind the rad fan also. My tuner, Lund, advised me to block the rad fan air from the filter.
    Here is my set up, if you missed it from my post.
  23. Likes JWolfe liked this post
  24. #20
    Jul 2019
    North Carolina
    Heading to tuning and dyno friday
  25. #21
    Jul 2019
    North Carolina
    Jul 2019
    North Carolina
    Port Charlotte, FL
    Sounds and looks awesome!
    Henry
  28. #24
    Jul 2019
    North Carolina
    20200731_083640.jpg She tuned out to produce 383 HP with 354 torque
  29. #25
    Jun 2017
    Just for the CJ part... Here is mine. Obviously not checked with 100% body clearance yet.
    As mentioned the Drivers side footbox is real tight and the panels I believe are coyote specific (Although I modded mine for more clearance). There is an assortment of coyote parts that comes when you order the kit but really just need the engine mounts and maybe the coyote pedal bracket from FFR. I ended up not using several of the small parts. Like to make the heater hose eliminator. Go to the instructions part of FFR's parts site and download the coyote installation instructions.
    Michael aka @my_cobra_build on Instagram
    Base MK IV Roadster with several options. Body is Lamborghini Grigio Lynx w/ Audi Vesuvius Gray stripes. 25th Anniversary FFR wheels. Seats and interior by Intatrim.
    Gen1 Coyote w/ Comp Cams & Cobrajet manifold. Tremec TKO 600 w/ a midshift kit. 2015 IRS w/ 3.73 Torsen diff. FFR Headers, Gas N Pipes, Power steering & power brakes.
