Nice progress, JB. Like you, I’ve been thinking about how best to coat the panels that weren’t powder coated. Picked up rustoleums professional primer and top coat aerosol specifically for aluminum. Tested it on my dash brace to see how it is and it looks good. Similar to your experience, slightly uneven application and will likely show knicks from road debris kicking up, but I’ll be easy enough to touch up.
MKIV Complete Kit #9494 l Delivered 1/5/19 l First Start
11/28/20 l First Go-kart
4/11/21 l Carb'd 347 l Mid-shift TKO600 l 3.55 IRS l P/S l Forte Mechanical Throttle Linkage l RT Turn Signal, Drop Trunk l Breeze Upper/Lower Radiator Support, Fan Shroud l Boig Upper/Lower Cool Tubes & Quiet Pipes l 18" FFR Gasser Wheels l
