Looks like you are progressing well... FWIW ... just an observation - the placement of the fuse panel with the dash completely installed may not be that easy to get to... have you put the complete dash in with the side close out panels to see if you still unhampered access?
I assume you are going to carpet the interior? If the coil or better yet the MSD box fails.. maintaining this area post build ... might be a little frustrating?
Looking at your panel... take a look at mine..
the ignition switch with the complete dash is about even with the switch - hard to see the angle but with the key in the ignition the back of my hand is in contact with the bottom of the dash.. then as the dash drops down and tunnel cover comes up .. there is only like 2.5 inches or less to get your hand to reach the top of that panel and it narrows quick after that....
anyway ... my opinion only... not that you were looking for the input
looking forward to hearing you hit the start button!!!
