Thanks Thanks:  4
Likes Likes:  9
Results 1 to 26 of 26
Thread: newer MKIV body - front tire options?
    Folsom, CA
    Question newer MKIV body - front tire options?
    Since the MKIV 25th Anniversary was launched, FFR is changing the body in a few places - namely the license plate, taillight mounts, rear wheel openings and more space in the front
    what options are available for 18" wheels? will 275s fit now without rubbing?
    Todd
  2. Likes Jdauble liked this post
    Jun 2019
    Atlanta, GA
    In the video that Dave Smith posted about it, he specifically mentioned 275's up front. I ordered 265's for the front, just to be safe.
    25th Anniversary Roadster #12 of 25
    Gen 3 Coyote
    TKO 600 mid-shift
    Car
  4. Likes toadster liked this post
  5. #3
    I wonder how these larger tires will affect rolling resistance, (which is essentially the energy loss that occurs as a tire rolls through its footprint)?
  6. Likes toadster liked this post
  7. #4
    Folsom, CA
    Quote Originally Posted by AC Bill View Post
    I understand that - but this is a 'smiles per gallon' car, so I probably won't be hypermiling more interested in the energy that it absorbs in the corners
    Todd
  8. #5
    Finally. Sure glad FFR got to these needed changes.
  9. Likes toadster liked this post
  10. #6
    Oct 2017
    Quote Originally Posted by toadster View Post
    When did they make this change? Mine is number 9191. Thanks
    MK4 #9191, Gen 3 Coyote, T56, 2015+ IRS, ABS, 12.88 Wilwood's, FFR Tubular Front LCA's, FFR Spindles
  11. #7
    Folsom, CA
    Quote Originally Posted by dhuff View Post
    they announced the change with the 25th anniversary car back in August, not sure if it's made it into the standard rotation yet...
    Todd
  12. #8
    whoa ! 275's up front!.....starting to get the footprint of an INDY car......yet they will still chew you up and spit you out in a mild off camber turn without giving it a second thought ….On a lighter note. You will sure look good sitting backwards in the dirt, in a cloud of dust, wondering what just happened.....BEEN THERE ! DONE THAT !...da Bat
  13. Likes toadster liked this post
  14. #9
    It's funny that 275s on 9x17s were pretty much the standard setup until the MkIV. I have never run anything less than 275 on my old MkII.
  15. #10
    Could you post some pic's with those tires on it. Curious how they look.
  16. #11
    275s on 9x17 Bullets and 315 on 10.5 Bullets
    IMG_20140821_080001_434 by craig stuard, on Flickr
    IMG_20140821_080048_810 by craig stuard, on Flickr
    Remember this is a MkII.
  17. Thanks AC Bill thanked for this post
  18. #12
    Jun 2015
    Fairfax Station VA
    Here are my Nitto G2's in 275/40ZR17 front on the 17" Halibrand wheels. Note that I've done NOTHING to the fender wells bodywork-wise.
    IMG_4997 by jhsitton, on Flickr
    IMG_5005 by jhsitton, on Flickr
    IMG_5009 by jhsitton, on Flickr
    MK IV Roadster #8631
  19. Thanks AC Bill thanked for this post
  20. #13
    Nov 2018
    Chandler, AZ
    I have 275 fronts on mine. They looks awesome and no rubs. But hit a rut in the road, and you better have both hands on the wheel. Mine isn’t a racer, so can’t give an opinion on that.
    Factory Five Racing Roadster MKIV -- #9196 -- 347ci, 475 HP, 5 Speed, Plymouth Prowler Orange Metallic
  21. #14
    I don't know where people got the idea that 275s won't fit on the front of a Mk4??? Unless you're running an abnormally low ride height, using wheels with funky offsets or the wider 1996 and up Mustang spindles they fit without issue after doing the usual trimming and shaping of the wheelwell opening returns (sometimes even before).
    Quote Originally Posted by RAMRobAZ View Post
    That's bump steer which has nothing to do with tire size.
  22. Likes toadster liked this post
  23. #15
    Haslett, MI
    Old post I know, but I'm looking into wheel/tire combos, and couldn't find newer references.
    Does the post 25th anniversary MKIV require steering rack limiters and/or FFMetal F-panels to avoid rubbing on the aluminum? I'm assuming the above is only referencing body rub.
    Thanks!
  24. #16
    Folsom, CA
    Quote Originally Posted by mmklaxer View Post
    Thanks!
    nope neither should be needed in this case...
    Todd
  25. #17
    They’ll rub. Virtually any tire size will at full lock which isn’t something that comes into play during normal driving (unless your normal driving involves trying to make 3 point turnarounds inside of your garage ).
  26. Thanks toadster, mmklaxer thanked for this post
    Likes toadster, mmklaxer liked this post
  27. #18
    No issues Front NITTO NT-01 @ 275/40ZR17-98W Rear NITTO NT-01 @ 315/35ZR17-102W. Prior front till it wore out at 9,000 miles was a 255 NITTO 555R also 315 555R in the rear.
    Car runs a 4.25" ground clearance
    FWIW the Nitto NT-01 275 18" 35 aspect ratio is the same dimensions as the NITTO 17" 40 aspect ratio version.
    17" 25.55 tall X 10.91 wide 18" 25.55 tall X 10.91 wide
    Kevin
    MKIV #8234
    NITTO NT01 275X40XZR17 - 315X35ZRX17
  28. #19
    Haslett, MI
    Thanks Bear. I was looking at the NT01's; planned on going with those for the first set and see how the 100 treadwear holds up.
  29. #20
    Aug 2020
    Kwajalein, Marshall Islands
    275x17x40 Front
    315x17x35 Rear
    3 inch ground clearance
    MK3 Challenge Car
    MK3 Challenge Car, Boss 347, Sniper 2 EFI
  30. #21
    Where you live ME will impose a number of limitations on your using the car. Temperature under 40*F traction progressively goes away, wet roads will require very smooth driving, car will not move in snow.
    In NC car is used all year with some days parked due to weather. Realistically with a few local level AutoX thrown in you should get 8,500/9,000 miles out of a set.
    This is 6 AutoX + 9,200 miles on 100 tread wear one of my NITTO 315 555R
    Installation NT-01
    4.25" Ride height NT-01
    Kevin
    MKIV #8234
  31. #22
    NT-01 with 4,500 miles and about sixty 45-50 second autocross runs.
  32. Likes BEAR-AvHistory liked this post
  33. #23
    Haslett, MI
    Installation NT-01
    Cost of doing business in ME - short driving season.
    You bring up a good question. I assumed these cars with ANY summer tire would be squirrely under 40 degrees. Even with 555 G2's, I wasn't planning on driving below 40 degrees. Is that a good assumption, or would a different "commonly used" tire on these cars extend the driving season? Not talking wet - different animal there.
  34. #24
    The Nitto NT-01 and Toyo R888R (I’ve run both) drop off dramatically below 60-65 degrees. In fact the manufacturer recommends not even storing them below 35 degrees, much less driving them at low temperatures.
    The Nitto 555G2 can tolerate lower temps although good sense and prudence still needs to prevail because they won’t perform the same at 40 as they do at 80. Falling in between is the NT-05.
    Haslett, MI
    Very helpful, as always!
  36. #26
    No I think you have a little more latitude than 40 as a drop dead point for the 555G2.
    I can be a DUMMY on occasion. Should have qualified my statement with:
    G2 comes in 2 flavors 320 & 200. The 320G2 has a higher treadware rating than my Michelins. The 320 would be a good choice.
    All my cars run on summer tires. Michlen PSS or PS4S (300TW). Have had no major issues in the high 20 degree range. The tires are less competent from 40*F down but they degrade slowly do not suddenly go squirrelly.
    Issue with them is this warning by Michlen.
    "Michelin warns that PSS cars (and P4s) should not even be moved if the temps are 20 or below. The cracked sidewalls that may occur will not be warrantied."
    The NITTOS traction will degrade faster with the lower tread wear compound.
    No sure what the "you don't want to drive" temperature is for the NITTO's they are rated at temperature A but this is a heating index not a cold rating. Have seen 40*F posted but its been by regular guys. They might just be repeating the standard "summer tires" number.
    Have gotten a little sideways launching with the NITTO 555R (100) at 39*F early in the morning, street may have been damp. Only happened once was my fault with a clumsy clutch release.
    With the NITTO's I use the BEAR body thermometer. If its too cold for me its too cold for the tires, usually 50*F+.
    Interesting picture, drive from painter to tuner, did not self destruct.
    EDIT: Should add that I did trailer the car home about 80 miles. Also G2 - 200/320TW
    Kevin
    MKIV #8234
