Thanks Thanks:  21
Likes Likes:  132
Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 121 to 160 of 265
Thread: Cliff's 33 Hot Rod Build in Virginia
  1. #121
    May 2018
    Pinckney, MI
    I have spent a lot of hours on the doors and I feel there are still a bunch more to be spent. Adding washers so the beam twists is a big help. Still is a lot of trial and error with way too many adjustments available. I have final fitting to go but just had had enough bodywork and went on to the chassis. The hood, sides, and radiator fit are another learning experience. Lots of options for learning how to sand, cut, and use fiberglass and resin. Not all bad, but takes a while when you are learning it all new.
    - Peterh226
    35 Hot Rod Truck (Ext) Delivered 11/21/24
    33 Hot Rod Gen 2 #1134 ~1400 miles
    54 Pontiac Star Chief
    05 F-150
  2. Likes Chris C, colsen23153 liked this post
  3. #122
    Virginia International Raceway
    Cliff,
    where are you? My family is moving back to VA shortly.
    33 Hot Rod #1133. LS/TKO600
    Delivered 6-17-19. Started work 7-3-19. First start 9-6-19. First drive 9-24-19
    Titled 2-28-20
    MkI.IV 2643k
  4. #123
    Jan 2019
    Sandy Hook, Virginia
    Quote Originally Posted by sethmark View Post
    Cliff,
    Sandy Hook 22 miles west of Richmond
    '33 Hot Rod Chassis #1118, Gen 2, hard top, bike fenders, AC, electric steering. BluePrint Engines Chevy 383 Fuel Injected with the 700R4 transmission 8.8" rear 3.55.
  5. Likes wrp, Aircontroller liked this post
  6. #124
    Not too far away... we’re moving near Roanoke....we lived in chesterfield for a while.
    Titled 2-28-20
    MkI.IV 2643k
  7. Likes wrp liked this post
  8. #125
    Jan 2019
    It's been over a month since my last entry. Since then I have over 20 hours working on just the drivers door. When you think you are done sanding, think again. It's a never ending process.
    I also took a break and worked on my punch list items. That list doesn't seem to get smaller.
  9. Likes FF33rod, wrp liked this post
  10. #126
    I feel your pain brother. I have just now gotten both doors and trunk lid open and close. It was a lot of work. If I were to do it again, I bet you I could do it in two hours. But the first time is abysmal.
    Titled 2-28-20
    MkI.IV 2643k
  11. Likes FF33rod, wrp, AJT '33 liked this post
  12. #127
    Jan 2019
    Great progress. Question: Did you just sand to get the doors and trunk lid to fit or did you rough cut most of it off first?
  13. #128
    The first one I snuck on with a DA sander. After that I went with a angle grinder to get it close. Then DA.
    Titled 2-28-20
    MkI.IV 2643k
  14. #129
    Jun 2018
    North Vancouver, BC, Canada
    Same - angle grinder with 40 grit flap disk, be careful that sucker will destroy anything it touches....
    Gen 1 '33 Hot Rod #1104
  15. #130
    Jan 2019
    Thank you both. I was leaning to go with the angle grinder for the other door and trunk. I was just using a sander and it takes so long.
  16. #131
    No.... not a 4.5” grinder, a 1/4” die grinder with a 3” pad.
    Titled 2-28-20
    MkI.IV 2643k
  17. #132
    Aug 2013
    Gatineau, Quebec, canada
    Quote Originally Posted by colsen23153 View Post
    If your adjusting your door or trunk for gaps on the edges then I would highly suggest a belt sander with a 60 grit belt, this way its straight and uniform. It will go fast so be very careful. Grinders can give you a wavy edge if your not careful or "destroy" the edge as FF33Rod mentioned. And if your adjusting your edges for gaps, remember that 1/4" and 1/8" tape will be your best friends to make sure you aren't guessing how much material to remove.
    I placed blue tape on the body side so I knew where the body edge/corner really was, then I went ahead and laid down 1/4" wide tape from the blue tape edge onto the door, this sets the real gap. Then I laid another run of 1/4" tape beside that one on the door side and removed the one that set the gap, the second one is where I would need to remove material to. This keeps the lines straight and true to the body. Have fun!!
    20180621_192456.jpg This is the trunk after belt sanding, the gap looks big but it isn't, between the 2 coats of primer, base coat and three coats of clear, it closes in nice and tight fast.
    Andreas
  18. Likes FF33rod, sethmark, Bgardner liked this post
  19. #133
    Jun 2018
    I have a couple of these t-bar style sanders from a previous hobby, thought they would be great to make sure edges were straight....
    http://www.greatplanes.com/accys/gpmr6170.php
  20. #134
    what did you use to fill when the gap was over?
    Titled 2-28-20
    MkI.IV 2643k
  21. #135
    Aug 2013
    If there was too big a gap, anything over an eighth of an inch I simply added some fiberglass to the face of the edge, made it flush front and back and then started over with the taping until I got the 1/4" gap I wanted. For under an eighth, I used my rage to build it out, it also depended where it was, on the front edge on the drivers side I used fiberglass knowing that I wanted a stronger corner.
    Andreas
  22. #136
    Jan 2019
    Well I finished the doors and moved on to the trunk. I put the weatherstrip on then cut off about 1/8-1/4" from the bottom. Sanded all the sides and it fits but the center of the trunk on the sides is about 1/4" proud of the body side. 100_2364.JPG I can push it down to rest on the weatherstrip so I don't think that is what is holding it up. It sits flush on the top and bottom but bowed in the center.
    Did any of you had this problem and if so what corrected it?
    Cliff
  23. #137
    Haslet, Texas
    Cliff
    Some have used Tim Whittaker's Side Stiffeners to help with this issue. Others have drilled holes through the inner wall of the trunk and then glassed the top to the bottom to add strength and rigidity. I am sure there are other fixes to this challenge that many other builders have used as well, but it does tend to be known issue.
  24. Likes FF33rod liked this post
  25. #138
    Simi Valley, CA
    Yeah, I'm in the midst of dealing with a potato chip shaped trunk lid. My approach is a steel tube frame that will be bonded into a slot I cut in the trunk lid. I'll use a combination of screws and washers/spacers to coerce the lid into the right shape before bonding the parts together with HSRF. 20191015_192247.jpg20191015_192413.jpgThe frame also gives me a place to attach the Mazda 3 hinges that I'm using instead of the FFR hoop hinges.
  26. Likes JOP33 liked this post
  27. #139
    Aug 2013
    Cliff
    Had a similar issue, had about 3/8", send a note to Tony Z and they sent me a new trunk lid that fit perfect.
    20180621_192338.jpg Prior to receiving a new trunk lid.
    Andreas
  28. #140
    Jan 2019
    It sucks having to make that very custom part for a flaw in molds at FFR. I'm almost to the trunk lid myself and fear it'll bow just like others.
  29. #141
    Quote Originally Posted by tony View Post
    Mine fits well. Fiberglass is fickle....
    Titled 2-28-20
    MkI.IV 2643k
  30. #142
    Jun 2018
    Just did the first fit (no gaps) of the trunk last weekend. It appears to be the right shape all around (unlike the doors). However, I have the Tim Whittaker reinforcement parts that I will be adding anyway to give overall better robustness.
  31. #143
    Simi Valley, CA
    Mine is a Gen 1 Hot Rod, so maybe this is an issue that FFR addressed in the Gen 2 bodies?
    Keith
  32. #144
    Jan 2019
    Sent email to Tony Z. to see if I can get a replacement. Fingers crossed.
  33. Likes Chris C liked this post
  34. #145
    Jun 2018
    Don't expect immediate response. Tony is OOO, at SEMA I imagine. Chris and I are still waiting for him to get back to us regarding the striker location problem we have with the Gen2 chassis mated with everything else Gen1.
  35. Likes Chris C, colsen23153 liked this post
  36. #146
    Jan 2019
    Do you believe in the tooth fairy? I some time think there is a FFR fairy. After sanding the uneven top edge of the trunk lid then drilling and installing the rivnuts, I put the lid back on and almost all of the bow is gone. I can't explain it because I had it off and on many times before. I did notice that as I drilled for the rivnuts I hit a layer of aluminum. Not thick but got metal drill shavings. Maybe because the lid was upside down when drilling it might have stretched out.
    Now on to mounting it and finishing putting the aluminum in the trunk.
  37. Likes FF33rod liked this post
  38. #147
    Jan 2019
    That looks like a lot of work. But it looks nice.
  39. #148
    May 2016
    North of sacramento Ca.
    My trunk lid changes hot to cold. Will build some kind of fram.
  40. #149
    Simi Valley, CA
    It IS a lot of work, but everything I do requires learning a new skill which (for me) is a big part of the fun of building a car. It means that my build is taking years longer than others. However, the result is that I'll end up with something unique that is exactly what I want and I'll know every corner and fastener. YMMV Keith
  41. Likes FF33rod, colsen23153 liked this post
  42. #150
    Feb 2018
    I recommend adding something for support. lots of ideas from all replies.
    The feel is much better when opening and a little reassurance that more movement wont be happening down the road. I am even thinking to do some support side to side. Idea from Progmgr1 would give this support
    My steps are now on my build page
  43. #151
    Simi Valley, CA
    The front to back bulge was the worst, but I also had some side-to-side warping. A little (1/4") high in the middle both top and bottom, but the PS back corner was 1/2" or more low. I understand that there is a lot of difference from lid to lid, especially on the older cars. So yes, I would suggest a frame all around. Either wood or metal should work fine. It just has to be stiff and able to be bonded to the lid. Keith
  44. #152
    Jan 2019
    A follow up from my email to Tony Z. about my trunk lid: Tony replyed a few days after he returned from SEMA and said he was going to send the lid. I emailed him back in a hurry to tell him it was not needed. Great response from Tony.
    I finished putting DEI header wrap on the headers. Not so bad a job.
    I moved on to installing my windshield. On page 472 of the manual there is a template that shows the exact location of the holes. I looked for that template and could not find it anywhere. I contacted tech. and they said it's part # 33489 in box 16. I searched again but could not find it. Box 16 is the aluminum parts and templates. If it was in that box it would have to be a box over 4' long. I asked them to take a picture of it and send it to me.
    I asked on Facebook if anyone else had the template and I didn't receive a yes from anyone. I got responses like it's printed on/in the windshield box or maybe the foam. Nada.
    I did put the hard top on to make sure that the holes for the windshield will be covered by the hard top. Here is what that looks like:
    It does cover the initial windshield hole markings but WOW! I immediately fell in love with the hard top again. My plan is to first build it as a roadster. Then a year later put the hard top on. I don't think I could last a year without the hard top. Seeing the car at that stage has given me the new enthusiasm I needed to Get'er done!
  45. Likes FF33rod liked this post
  46. #153
    The template for the roadster windshield is the gasket.
    Titled 2-28-20
    MkI.IV 2643k
  47. #154
    Jan 2019
    Dan @ Tech. also said it's the gasket. I'm disappointed as what is shown in the manual would take all the guessing out of it. The holes in the gasket are larger then the 1/4" bolt. I will "measure twice and drill once."
  48. #155
    It’s a pain. I had to widen the holes a bit each time. And I measured many times. Be aware that the bolts suck the cowl up to the windshield frame.
    Titled 2-28-20
    MkI.IV 2643k
  49. #156
    Jun 2018
    ... WOW! I immediately fell in love with the hard top again. My plan is to first build it as a roadster. Then a year later put the hard top on. I don't think I could last a year without the hard top. Seeing the car at that stage has given me the new enthusiasm I needed to Get'er done!
    Yup, I felt the same when I did that last week...
  50. #157
    Feb 2018
    As sethmark states the cowl does get pulled up to windshield as you tighten the nuts. I notched a piece of angle aluminum and shaped it to fit on the underside then epoxied it with the windshield installed, then I epoxied a piece of flat stock over the notches to hold the shape. When i remove the windshield the cowl holds its shape.
  51. Thanks sethmark thanked for this post
    Likes sethmark, JOP33, Mrallsport32 liked this post
  52. #158
    Jan 2019
    33 Hot Rod Windshield install with heater/defroster
    While attempting to install my windshield today I ran into a problem that is caused when having a defroster installed. They say at the end of installing the windshield that if you have a defroster to cut the vent holes now. Well you can't use a air saw to make the cut with the windshield installed. So I went about installing the defroster first. I measured, cut, and installed the complete defroster and defroster duct work. This is where I ran into a problem. With the defroster duct installed the center bolt for the windshield strikes the defroster duct. I could not find anything in the manual or the defroster instructions telling me to avoid the problem. So I had to uninstall the defroster duct work to get the windshield to sit flush with the dash again.
    The problem is simple to correct. Two solutions. Cut the center bolt before installing it into the base of the windshield (don't cut the hex end) just long enough that it can take the 10mm nut and washer but not longer or get a 6mm button head screw about 1" long and insert it from underneath before installing the defroster duct. I am going to try the second choice. I will let you know after I finished what the length turned out to be.
    UPDATE: I used a 6mm pan head bolt 3/4" long. I had to tighten the bolts on either side to "flex" the body so the bolt would catch some threads. Worked fine. Defroster is installed and functional.
    Here are some pictures of my progress:
    This picture is the top of the defroster duct where the center windshield bolt was hitting. 100_2375.JPG
    I made a template out of the flap of the windshield box. I pushed it up against the bolts to get my location. It wasn't exact. I had to widen a few to allow the windshield to fit.
  53. Likes FF33rod, TxMike64 liked this post
  54. #159
    Jan 2019
    On to the headlights. If you think something is going to take you a few minutes add 2 to 4 hours to the estimate. Two things were wrong and one bad part. If using the Ron Francis wiring harness the gauge of the 5 wires that go thru the head light mounting bolt will not fit. The head lights are LED and don't require that heavy a wire. You could use lesser gauge wires or drill out the mounting bolt for the wires to fit. I chose to drill the bolt. Use these drill bits in succession with oil. 19/64, 5/16 and 21/64. They will just fit if the wires are not twisted. The second thing that was wrong is the color code on the lamp as what is in the manual. I just used a battery and alligator clips to determine the colors to use.
    I chose to wire it up for the DRL. I think it looks cool. To do this you need to supply +12 to the red wire on the lamp. I used the RF parking light wire. Back in the cab I cut the brown wire coming from the front harness and wired it to the electric choke wire. This turned on the white led bar and allowed the it to change to the directional amber.
    The bad part was the head light switch. It didn't switch on the head lights. I just happen to have a second one in my spare parts box and that fixed the problem.
    To finish up the day I worked on lowering the front to the required height of 4.5". I was able to get it to just under 6" and called it a day. I'll look at it again after the holiday.
    Happy Thanksgiving y'all!
  55. Likes FF33rod liked this post
  56. #160
    I extended the headlight harness out of the bolt into a weatherpak connection. Same pain in the butt. Nice job.
    Titled 2-28-20
    MkI.IV 2643k
