mike223
I'm using a Grant steering wheel, very similar to GoDad's, except mine has a yellow stripe at the top.
The stripe is there so you have a reference for getting the front wheels straight (an *extremely* high priority when you exceed traction with the rear - if you have any idea what's good for you).
Very little dish on the steering wheel - and smaller diameter steering wheels almost *require* power steering.
Also very similar on the quick release - I used this one (and had to hand machine an adapter):
https://www.ebay.com/itm/Longacre-52...ss!37921!US!-1
P.S -
I am very likely to change over the the Jeg's quick release - as soon as GoDad confirms that a Grant wheel bolts straight up (no adapter - I'm always looking to eliminate complications).
Confirmed Mike223,
The 5 Screw Grant Wheels fits on the Jegs Quick Release.
I also have an extra steering shaft if you need it since the Jegs piece welds on.
You can see the quick release around 1:50 minutes into this video which still has my old Grant Wheel mounted on it.
https://youtu.be/_wnHDNgnNqs
