0
0
Thanks Guys, info appreciated as will additional from other sources.
BadAsp427, I was thinking the movement would be in the 3" range but as Jeff mentioned spring rates will change things. Jeff, the wire ties are pretty standard for evaluating compression, any good way to measure extension?
I'm a long ways off from any driving concerns but I am trying to gauge travel and then tire widths and wheel offsets.
Jim
