14
75
View Poll Results: How to finish the mesh panels?
- Voters
- 58. You may not vote on this poll
Gloss Black
Unfinished Aluminum
Back on the Horse
This update has been a long time coming -there has been no point on writing about disassembling the car or refreshing the motor.
So… not quite done yet, but the ‘new’ motor is in.
The fuel system has been overhauled – installed a HydraMat which required significant modifications to the tank, replaced or replacing the fuel lines and filter.
The wiring has been worked over -behind the dash is moved and re-organized. Not really better, but the fuse box is now in the passenger foot well.
The Engine & bulkhead wiring harness is cleaned up a bit and we’ve added the control wires for the intake AVCS.
We will keep plugging away
