Tony Nadalin
2022 SOVREN Championship
2018 SOVREN Big Bore Champion
2012 ICSCC ITE Class Champion
I removed all the quick latches (I had used 7 on the rear decks) and just went with standard hood pins, but black posts and carbon fiber scuff plates.
Tony Nadalin
Did you find that the hood pins easier to use, or was it more a question of the reliability of the quick latches?
Tony Nadalin
Do not use quick latches on the engine access panel(s)! We did, not good when fire is involved, the get stuck. Aero latch or sliding hood pins! They ended up just ripping it off our car to get to the fire
Thanks- Chad
did you/are you going to spray clear over the cf wrap?
Tony Nadalin
I found, at least on the CF wrap I used on my interior trim pieces, that applying ANY top coating over it (I tried a eurethane spray-on clear coat and some clear epoxy laminating resin) causes it to turn solid block with zero CF texture or pattern appearing beneath the clear coat. I was using 3M CF look wrap.
Surprisingly, Fire on the outside of the engine was NOT in the plan, but thank you for the input.![]()
Everyone is a comedian, I will have my revenge.![]()
Major milestone, I emptied the last box over this past weekend, no more FFR boxes !
Tony Nadalin
That is satisfying!
You access it by taking the seat out on the inside. 2 barriers (3 with bladder) and more distance than the 818 from the motor (more than double). Plus no hot headers inches from fuel cell- that's why I moved mine on the 818R to passenger compartment. Better weight distribution also.
Thanks- Chad
Our experience is that you are not going to change the weight distribution, once corner balanced and a cross balance of 50% the distribution of the 818 will still be 40/60 with the tank anywhere within the roll cage area, as we played with this and no difference. Moving tank up front out of the roll cage area may make a difference, we did not play with that.
Tony Nadalin
Thanks- Chad
Tony,
Have you gotten the Race Capture Pro setup working with the OBDII to CAN adapter?
818R Build date 10/31/15
Tony Nadalin
Good to hear it's all working. I'm anxious to get mine up and going, kind of need to finish the rest of the car too.
What data are you logging via CAN vs. direct connections to the RCP?
Tony,
A while back you had ask how high my wing is off the rear deck. Well playing with the car today at lunch I remembered your request. My wing is 9" from the highest point on the rear deck to the bottom of the wing.
Hi Bob, and yes rubbing on it is a nice way to relax during lunch
I have the APR GTC 300 that FF sells, AoA measured at the cent of the wing is 2* currently.
We have a Mobil station on site with 87, 93, 98, 104 and 110 octane fuels, I had the the engine tuned to run 93.
We going to see you at 10/10ths, MVP or our event next month?
I am getting ready to head to the track next week and needed to get my wing up higher above the roll cage, so I sent Doug at FORMACARs a cad file of what I wanted and he produced some excellent quality CNC 1/2" T6061 Aluminum wing struts for me. So I am now 6" above the top of the roll cage bar, so 18" off the rear deck as before I was at 11" above rear deck, even with roll cage.
54C77EE4-59A6-44CD-BDBA-E2020C53233B.jpg 465FE532-544C-489C-80E3-B5F438B17C84.jpg IMG_1135.jpg
Tony Nadalin
Now, set your wing to 0-2 degrees and enjoy! The difference now that you are out of the shadow of the cage will be youge!
Tony, nice mounts! How did you land on 1/2" thick? Based on the recommendation of my wing builder, I was going to use 3/16" and then add some cross bracing.
Tony Nadalin
Nice Tony, have fun and looking forward to a report.
Lookin Good!
Tony I take it this means you'll be at the The Ridge Enduro? How about you Jeff?
Owner: Colonel Red Racing
Car is going in to the tuner for dyno work and break in. We have tires ready to go, so it's up to what happens this weekend on the new rebuild. We hope yes.
retroracing is that your car that caught fire in turn8 at the ridge.
If it was blue with a white roll cage and hump, then yes. Please don't tell me another 818 caught fire there, I might do damage to myself.....
I finished up the data logger and virtual dash this weekend, so almost ready for the track if the rain stays away for more than 2 hrs
Tony Nadalin
New prototype JDI display/tablet going in, should be bright enough at 1100 NIT
Tony Nadalin
Track time today, I lost all power, no boost, and smoke out the exhaust, it's a VF30 turbo
Tony Nadalin
Hi Tony, can I ask where you got that JDI display? I can't seem to find a supplier.
Speedy G
Tony Nadalin
Car looks great... turbo doesn't -major shame!
Did you get some good track time in, or did it let go immediately?
Oh man the turbo! Sorry to see that.
I assume the bearing went, which means you have metal shavings in your engine oil. You'll need to pull the oil pan off and check for excessive glitter. You know what happens from there.....
