If you are replacing the tanks, go with the aluminum tanks. You may also want to consider having them notched at the top to keep the fill hose from being pressed against the body, and being kinked. It made a huge difference in mine. And now fuel can be put in without it taking 20 minutes.
Tony asked if he could put a drain in the bottom of each tank that would allow them to be drained when needed. I said "Heck Yeah"!
I think it cost about 300 or so to have these two things done. But in the long run, I think it was money well spent.
