22
Moonlight Performance
Wow there's a name I haven't seen in a minute. Glad you are still at it. Smart move, glassing over the studs. I have had several studs pop off on me - even ones that had low load on them (ones that were holding Mechie's hood louvers in place). But after I started glassing over them, I haven't had an issue yet, even on the studs that are forcing the headlights upward and have a ton of pressure on them. Your's should hold great.
