It's been quite awhile since I've updated my build threads. Over summer I took some time off from the build as it started to feel like work instead of a hobby. My time has been limited since starting back at it but I have been making a bit of progress.
I have finished leveling all of the body panels. When FFR pulls them out of the molds they have more lip than necessary, which creates panels that aren't flush with one another. Some careful measuring/planning and a belt sander has rectified that situation.
I have also finished the mounting of 4 of the quick release latches (the small black circles) that are holding the engine/rear cover down. I'm thinking I'll need 2 more for the engine cover, just to be sure it's not moving around while driving.
I've done some finish work in creating a carbon overlay for the center console and wired/installed the gauges.
This weekend I put together and installed most of the hood hinge that I'll be using. This is coming after many hours positioning the front end until I'm somewhat satisfied with it's fit. Needs just a touch of trimming at the rear of the hood corner, but otherwise it's not too bad. I'm not sure if you ever get truly 100% satisfied in these types of builds.
The hood hinge requires you to get creative in adding some studs to the inside of the hood. I've purchased some fancy hardware, high end 3m panel bond, and fiber glass to reinforce once that's all in place. Once all is finished with this it will tilt forward to open, which I always think is cool when I see that at car shows.
Hardware (resting position):
Open:
