0
0
Originally Posted by
RickP
You don't have to degree the cam. The reason you want to is to ensure the cam you have matches the cam card that came with the part. If you degree it, and it doesn't fall into spec with the card, you have the wrong cam. It's piece of mind knowing that piece of the puzzle is right.
if you were on the exhaust stroke when you set that chain on, your timing would be 180 degrees out. And yes, it's very possible that it is. Hence your symptoms. If your facing a tear down to ensure the timing chain is aligned properly, go the extra step to degree the cam while your at it. if you don't have a degree wheel, you can use mine. I'm about an hour from you near Pottstown.
That is very much appreciated. I am going to try and do the process at least one more time before tearing down. I went back to the main video I used as I was installing my timing chain and watched it again. I am damn near positive I did it right because I had my computer next to me and kept replaying it while I was installing it. It was the thing I was most freaked out about messing up. Here is the video. If that is right, it really should be in right and I am just being a dumbass with the other stuff.
https://youtu.be/NjalAvBQhVE
