0
0
Fuel Pump Shut Off After Crash!
While trying to decide which direction to go with a fuel tank (gen 2 FF, Boyd original, Boyd modified), a question came up about what happens if the 818 is in a crash. Does the fuel pump remain energized? In looking in the wiring, I do not see an actual inertia switch and in the WRX I suspect actuation of the air bag sensor also kills the fuel pump.
Am I missing something or do I need to plan for a switch to kill the pump in a case of an accident?
~ Mark
2001 NB Miata LS3 V8 440 rwhp
