One thing that has bothered me from the start of this contest is the roll bar. Many race cars feature full cages for added security. I do not race, but would love to get into it. The cost of this kit may enable me to do so. If I ever do get into racing, I would greatly prefer the added security and potentially stiffness of a full cage rather than just a roll bar. The Factory 5 challenge car does not have a full cage but it does have tube steel running from each top corner of the roll bar diagonally down toward the frame. Xabier drew this "semi cage" design on his track version. The challenge car also has the benefit of its long hood with the heavy engine in front of the driver acting as a crumple zone. Since the 818 is mid engine, the need for protection of the cockpit is much greater. For the 818 in a frontal collision, the momentum of the engine, transmission and fuel tank will push through the cockpit, effectively turning the cockpit into the crumple zone. The way the 818 frame is currently designed, it seems to me that it would tend to fold like a jackknife right about at the driver's legs.
Here are some examples of some nice cages.
It seems to me that a cage would also be more adaptable and therefore lend itself better to the single frame, many bodies concept. The added stiffness provided with a cage may allow for the framing along the side to be opened up a bit for a larger, more user friendly door. A cage would also be very good for those who want to install a windshield. For a version with a roof, a cage could be designed with a "T-top" roof and gull-wing doors like the Ultima GTR. I like this design because it has fixed rather than roll-up windows, eliminating some weight and rain proofing issues.
The downside to a cage may be added weight, but it might actually decrease the total weight of the frame by eliminating some of the steel down low. After all, convertibles are typically heavier than their coupe counterparts because of the extra heft needed under the floorboards for rigidity.
I'd like to hear opinions, especially from active racers and automotive engineers.
