First track weekend of the year at Autobahn Country Club, just south of Chicago, went well. Decided to put this info over here for those that don't check the other forum.
Total car weight with full tanks = 2,812 includes 200lbs added to driver seat.
Front left = 609lbs
Front right = 537lbs
Rear left = 843lbs
Right Rear = 823lbs
Ride height started at 4 1/4" front and 4 3/4" rear, haven't checked since corners set.
Tires are Nitto Invvo:
Front 245/35/ZR19 93w
Rear 345/25/ZR20-100Y
I have installed my new upper control arms from Mike and am very happy with my first track day.
Gen1 GTM had the tabs in the wrong location and finally there is a fix with mostly off the shelf parts. As you can see, I have finally gotten some good numbers on my caster and camber.
2015 (current)
Front
Camber -1.5
Caster 4.3
Toe 0.14 (1/16" per side)
Rear is same as last year
Camber -0.7
Tie 0.15 (1/16" per side)
2014
1/8" total toe front and 1/8" total toe rear (that is 0.22 front and 0.30 rear with my size tires).
Caster is at 3.1 and 2.7 degrees.
Front camber is -0.6 and -0.2
Rear camber is -0.6 and -0.5.
2013
left front
Camber -0.5
Caster 3
Toe .08
Right front
Camber 0.5
Caster 3.4
Toe 0.2
Left rear
Camber -0.6
Toe -0.3
Right rear
-0.5 camber
0.12 toe
I used to work with a suspension race shop in Kansas City when I visited my parents, but they have moved away. And although the GM shop was giddy the first time I came in for an alignment, by the third time they just sighed.
