Just so you are aware, those are ultra low quality two piece rod ends. They will wear quickly and then allow variations in the toe to occur. It is definitely a personal preference, but I will not put cheap rod ends or bolts on my cars. They both have too important of jobs. That said, we did have to make our own aluminum connecting rods for the rod ends. I believe I have about $600 in the rear toe links alone when it was all said and done. Again, this is a critically important part to tuning and safety, so I used nothing but the best and the rod ends were over $100 each by themselves. Out of that kit you show there the only thing I would feel comfortable using would likely be the ball joint stud adapters...maybe.
