Looks similar to the tunnel, but just shorter and at a sharp incline. It's also taller to fit the higher position. And it's very thick... 1/8" or 3/16", not the thinner stuff used on the tunnel.
Are you referring to the two metal clamp pieces that attach to the e-brake cables? Those come from the donor.
Do you need both the top and bottom pieces ?
Tony Nadalin
2022 SOVREN Championship
2018 SOVREN Big Bore Champion
2012 ICSCC ITE Class Champion
Here is a link to the sharable Google Sheet of a data log. As you can see, I'm new to open source logging/tuning and clearly am not that good at it. I could see my boost on the screen, but it didn't log it. I'll have to practice in the garage sometime. Same with coolant temps.
The track:
It's a small track. When my friend and I got there, we were the only ones there. Including owner/workers. And they said we could open lap as long as we wanted if we wore helmets and spaced ourselves out. I got a lot of seat time in a small (3rd gear track, 4th on straights and 2nd in a tight section) and bumpy track. Here are some pics.
The good:
Car did well for the most part. Coolant temps stayed below 190* all day. IAT's with the STi intercooler and NO top body piece were alright until I pitted and left it running. Then they'd shoot up. IAT's were over 100* with ~75-80* ambient and direct sun most of the day. Which isn't terrible, but it's not great. Track was fun and really relaxed which gave me a chance to play with tire pressures and a little bit of suspension stuff. No huge changes, but some learning on my part.
The bad:
Had a weird breaking up section towards the end whenever it came out of a longer right turn. Maybe it was just slightly low on fuel and it sloshed over. It was the same two spots on track each of the last few laps. Not sure what was up with that. Gonna try to match up GoPro footage with data logs and see if I can make heads or tails of it. The sky is going to open up on the track the rest of the weekend so I brought the 818 all the way back home tonight and may go back tomorrow/Sunday in my DD WRX.
The broken:
Nothing, as far as I can tell. My friend drove it and promptly spun it out. My minor tire pressure/suspension adjustments made the car "too easy to spin out". I blame it on driver error
Videos to come tomorrow or Sunday. Now I have to unpack the truck/trailer and then decide if I'm driving back to the (already paid for) track with my WRX in the pouring rain, or just skip it. Sigh. Weather really ruined a big testing weekend for me!
Glad you are doing what you set out to do and tearing up the track!
I agree that the issue you described sounds like fuel starvation as well. How full was your tank? To my recollection, the WRX ECU doesn't monitor fuel rail pressure, and if that's correct, you obviously can't log it. That would be the best way to go back and validate whether starvation was the issue.
Looks like a big Kart track but perfect for getting more time on the car. My guess would also be fuel starvation. I am encouraged by what you are seeing how your Air to Air intercooler is working with just having air pass over it.
Thanks for the report.
Mitch- no problem. It was a big kart track. With my 4.44 final drive I was hitting the top of third on the front straight and getting into 4th on the back straight. Really cheap and very relaxed track day. Not the nicest surface, but we had the track ALL DAY Friday and it was $25 a person. Can't beat it.
I am thinking that since it went lean on those corners (I loosely matched up data with GoPro footage) it was in fact fuel starvation. What's everyone doing about that?
I'm probably going to make a second thread about this in the fuel section, but here's the trouble I'm faced with:
-Stay with '33 tank, and keep it really full to avoid fuel starvation. Cheapest solution, but way less than ideal for driving.
-Upgrade to Boyd tank. Less fuel starvation since it's taller and thinner. ~$500 cost, and possibly I can't keep my fuel pump? Still doesn't eliminate the fuel starvation issue, but probably makes it a good amount better.
-Upgrade to fuel cell. Seems like almost every cell is square so I'd have to run it where Chad does. I really want to have the 818 as a street car with a passenger seat for at least a year or two, and that'd defeat most of the purpose of having it as a street car. Also, they're expensive as hell. Probably both the safest and the most performance based option, though. Anyone know if I can get a rectangular one for behind the firewall without breaking the bank?
-Hydramat. No clue how to make this work with our in tank pumps, but this would be a cheap way to possibly eliminate fuel starvation.
Any other options I'm not thinking of?
Tony had a fuel cell made that fits in the stock location, the price is not bad for a custom made cell.
http://thefactoryfiveforum.com/showt...ight=fuel+cell
Thanks- Chad
It's just more than I want to afford right now.
And yes, it's a little small. 16 or 17 would've been my guess for the "right" size. Maybe 22(I see that's a common size) is a better bet?
I was thinking about getting this guy:
http://www.ebay.com/itm/Universal-Po...-/201253630598
Instead of a Radium engineering one. While that'd be nice....they're EXPENSIVE. A surge tank is less work to install and more proven than a hydramat.
Hindsight, getting a new '33 or 818 tank and welding it at work is my backup plan. Pulling the tank would kinda suck, though.
Ordered a Radium unit; this one. It's only money, right?
Tony Nadalin
radium is pure engineering porn. I also spoke to them and I'm pretty sure I'm going with:
1x 20-0132-00
1x 13-0011
1x 14-0186
1x 20-0167-01
2x 20-0176
and a handful of 6an PTFE hoses
all the runs should be neat, short and returnless.
You guys realize I'm a dealer for Radium?
Frank,
Because I am running aftermarket fuel rails and ditching the OEM regulator (Located on/near the passenger oem fuel rail) I needed an aftermarket regulator.
I was originally planning on running the same surge tank as you using their multipump regulator (using only one pump)
after speaking with radium, I decided to go with the integrated unit as it reduces the amount of hoses needed, as well as the cost slightly.
I have the room and don't think i'll ever go with redundant fuel pumps so its a good fit.
Few laps around SLMP. Playing with suspension pieces and tire pressures in the quick time I had in the dry on track. Rest of the weekend was spent in the WRX in the pouring rain.
No updates for a little while, but I haven't done all that much work on it recently. I did install the Radium unit and will be testing it this weekend at NYST. I paid for both days, and it finally seems the weather will be on my side for them. Sleeping in the truck for both nights at the track.
Mid day update- I'm at NYST for today and tomorrow. It's going meh. The car started right up this morning and got up to temp. Then after the driver's meeting and tech and the other sessions went, it wouldn't start. So I missed the first session. Cleaned plugs and it started up. Then went out for the second session and came in after one lap. No boost. So I found a formerly plugged nipple on the intake manifold and capped it. Third session was okay, but my mind and confidence were definitely not in it yet. Hopefully the track dries up a little (rained last night) and warms up after lunch and I can get some better lapping in.
Good luck today!
Tamra
First autocross 3/29/15
Thanks Tamra!
The weekend at NYST went well. I had a boost leak that I couldn't find at first. It was probably better that way, because slowing down really helped my lines. Found out my intake manifold to BPV hose had a hole in it from heat (it rested close to the turbo). Simple replacement and the car was good as new. WOW it is freaking fast when it works well. Also my Radium surge tank held up very well; zero fuel starve, even when my tank was low. I absolutely love this thing on track. I rode in a few other cars...even if they're as fast, they don't compare in excitement to me. I have high hopes for the future in this car.
Had some mild heatsoak, played with suspension stuff a little, and tried to fix my line on the track. Also got to ride a friend's bike around the track- what a thrill! My parents came up for the day and rode in the 818 with me. They loved it. Such a fun car. Though it DEFINITELY handles worse with a passenger! It's too bad when they rode in it I had a boost leak. Also spun the car (after playing with rear suspension a little too much) with my dad in the car (video later). Nothing got damaged and we had a laugh.
Great photos - so beautiful with the fall foliage!! Glad everything went well.
Tamra
What a beautiful place with the fall foliage! I see it is a private track with memberships and event fees. I was wondering how it was that you were able to have people in your car (unless you have instructor status).
It's three hours away for me. Seems like it would be a good test and tune place. Easier than going all the way to Watkins Glen! I guess I'll have to call. I can't tell how they run an event.
I'm glad you are having a blast in the car. What's the longest time you were out for at a stretch? The overheating issues obviously come to mind. Was the heat-soak from sitting or a gradual buildup?
Good luck and thanks for sharing.
"Scotty, give me all the TRACTION she's got!" Pictures of what I drive till 818R is finished
Track Car Journal on IWSTI (with build info)
It was absolutely beautiful there. Amazing weather, too!
Scargo, it is a private track. I paid $250 per day for this weekend. On Saturday we did 4 sessions per hour (expert and novice car, expert and novice bike). We went from 9-5 with a lunch break so 7 sessions for a total of 1:45 on track. Sunday we combined the car group since there were almost no cars so we had 20 minute sessions and the last one went way long. A total of ~2:30 on track. The other time I went here with the 818 was on a Friday where a Subaru group rented the entire track. We did 20 minute sessions and I went out for the expert ones and some of the intermediate ones towards the end of the day (when there were almost no more cars left on track). I got over 2 hours of time that day, total. And a few ride alongs with instructors.
Once they get to know you (I've been here once before with the 818), they don't mind if you take a rider as long as you're a little more careful with your lapping while they're in there. It's a very relaxed atmosphere with camping on site, really nice facilities (showers in the bathrooms, everything is clean, food served on site), and a beautiful track surface. I'm likely going to get a membership next season and frequent the track. I highly recommend you come one day next year. A great group of guys and a decent amount of seat time. Also, a very technical course (you can see my first track day here to get a look at the track from the car. This is great for me because I'm certainly the most limiting factor in the car's lap times at the moment and it's teaching me a ton.
The overheating/heat soak happened when I did things like let the car idle for ~10 mins in direct sunlight trouble shooting boost leaks, then went onto the track. It also happened if I pitted mid session and then went back out. Besides that, airflow was fine there, likely mostly because I do NOT have the deck lid on(or whatever you call the non hinged piece over the TMIC). I know this drastically reduces aero, so I'm excited to have more grip someday in exchange for heat issues.
Sounds like another great day.
So no oil temp issues on your end?
Nice pix! And it must be really great having a car that runs!Or runs fast.
Didn't wanna rub in the oil temp thing with Chad's problems. 229 was all I hit according to the gauge. Didn't feel like it slowed down really except the heat soak thing when I idled a lot. Went away once I went down the straight.
Edit- again, I have an open top over the engine (doesn't fit with my TMIC) and it was only 55-70*ambient (in the shade, so plus sun). So it should be better now than once it's got aero completed. I wouldn't call it conclusive on my part.
Hey frank, enjoying your build. Glad your weekend went well. Had a skim through it once I realized your running the wheels I'm "trying" to buy. It seems impossible to find 17x8 or 17x8.5 wheels in the same colour as 18x9.5's. I can get the fronts in silver and gold, and the rears in flat black, bronze, and sbc. So frustrating. Waiting to hear back from a Canadian website offering them in all gold, fingers crossed!
818 SRX - #91
Arrived 01/02/2014
First Start 10/31/2016
First Drive 05/22/2017
Registered 10/25/2019 BRAP818
Thanks! I went through Oakos Automotive who found me my wheels, as you can see....in silver and gunmetal. No one has ever even asked or pointed out that they don't match. I don't mind the color mismatch, personally. Which is a damn good thing because it seems hard to get in the same color.
I can't wait to deliver on that one, Frank! Next season will be a lot more telling, I think.
