Triathletedave
Bob:
I tested the relays and headlight circuits again. I seem to have power coming into the headlight relay, and the relay works in a bench test, but the relay does NOT seem to work when installed in the main fuse box. How can that be? I also cannot read 12 volts coming into each headlight fuse now (confirming that the relay does not work?). Is there any reason why the relays would both work in a bench test, but not in the fuse box?
BTW, I am using a brand new battery in the car, and most other electrical systems are working.
check the 10 amp fuse# 13 in the tan fuse box. It supplies ignition power to the head light relay.
