0
0
Originally Posted by
dirty kurty
Given the 818's low profile and therefore low visibility to other drivers, you may want to keep the DRL even if they aren't required. Anything that helps the bozos see you is a good thing.
No offence, but if your worried about visibility then turn your headlights on since its brighter than the DRL. This way you can control the goofiness
. Also its proven that DRLs, like having a 3rd brake light, is ineffective at preventing crashes.
http://www-nrd.nhtsa.dot.gov/Pubs/811029.pdf
