Likes Likes:  4
Results 1 to 40 of 909
Thread: GTM roll cage modifications and race car build log
Threaded View
  1. #10
    San Diego
    Just wondering...do you use the clutch when shifting? If you look at our latest video from Utah I am shifting our Mendeola like it is going out of style and only had one or two hiccups, which were clearly my fault. The shifts are VERY quick and I am using the clutch every time. I really see no reason to shift without the clutch and plenty of good reasons to shift with the clutch. One of the biggest is that it seems to be WAY easier on the dogs. I realize this current issue was caused by the adjustment problem, but just thought I would make the suggestion if you are not already using the clutch every time. I know I rarely, if ever, used the clutch on my motorcycle/quad after starting from a stop, but these gear boxes seem to like the clutch use and I am all for doing whatever is possible to keep the wear issues down to a minimum.
    www.myraceshop.com
    GTM solution kits
    Corvette and Race parts
