That has always been the conventional wisdom, although if the oil temp is 250 degrees and the coolant is 190f, it would cool the oil. I removed mine as well, and had it removed on my track car with any problems. On my GT-R, there are coolant intercoolers that link to both the oil and the transmission fluid, so the are normally all very close to the same temperature.
I would be most concerned with the cause of the loss in power at higher oil temps. If it is due to timing retard, that can exacerbate the problem, as the reduced timing will typically increase both EGT and oil temps.
). So I don't think anyone can say that was not part of the issue. Yes, the car shows great promise...... All of them have not proven reliable on the track. Sure, I could autocross all day long with it and not have a problem, or go grab something at the store if it was street legal. Racing or tracking a 818R is a whole different story, especially if you are not "Putt, Putting" around the track. I could have a successful track day going 80%, but I'm not wired that way. I'm full on racing out there, even when testing (old tires limited). If it was 40 degree's outside (when testing the FFR 818R) I'm sure I would not have a problem with heat either.
