Great! That's what I'm using on the front. I had them lying around from a previous WRX I owned. I'm glad you are ahead of me and will figure out the balance before I have to sort out my rear brakes.Have just about settled on these for brakes:
Total brake package per wheel=25 pounds. That's brackets, pads and all.
Stoptech says the weight distribution under braking is very close to 50/50, so I can use the same caliper sizing front and rear.
Front: STR40/28-32 (28 &32 are the piston sizes), 328x28mm rotor
Rear: same as front
Master Cylinder Size: Front: ¾”, Rear: ¾”, Pedal Ratio: 5.61
